? about stearing rack need asap plz!!
Old Feb 24, 2009 | 04:10 PM
crxjarred's Avatar
Default ? about stearing rack need asap plz!!
ok i failed the inspection cus my stearing rack is messed up and i have pulled everything off and its hanging down the only thing holden it is the splined peace that gose up threw the firewall to the stearing wheel how do i get this off and i have to get this done tonight to go back up there tomaro after school to get it inspected plz help me thanks alot
Old Feb 24, 2009 | 04:14 PM
T.Rex's Avatar
Default Re: ? about stearing rack need asap plz!!
look under the driver dash where it enter the bulkhad there should be a 10mm bolt take it off and the rack should come down
Old Feb 24, 2009 | 04:16 PM
frank_el_tanke's Avatar
there is a 10mm bolt that connects the steering column to the pinion. in order to remove the bolt you have remove a plastic cover that goes around the bottom of the steering column. the plastic cover meets with the carpet and it will have these plastic nuts holding it down to the floor of the car. once you remove the plastic you'll be able to see the 10mm bolt. it will be all the way to the bottom.
Old Feb 24, 2009 | 04:17 PM
crxjarred's Avatar
are u talken about the lil back cover its under that
Old Feb 24, 2009 | 04:18 PM
crxjarred's Avatar
ok thanks i was typen that as u posted that sry but thanks a lot now dose this cover need to be there or is it just usless
Old Feb 24, 2009 | 04:20 PM
T.Rex's Avatar
up to you
it helps keep the dust from getting into your column, i would put it back.
Old Feb 24, 2009 | 04:23 PM
crxjarred's Avatar
ok i proly will later just to make sure that its all working right but thanks alot for ur help
Old Feb 25, 2009 | 03:10 AM
crxjarred's Avatar
ok well i found out u gota pull the bolt all the way so it comes outa the grove on the shaft figured that out and had trouble pulling the strearing rack out then peaced togeather all the new stearing rack like the inner and outer tirodes and got it all back up and atached everwhere and some how the shaft was up to far and i striped out the bolt that gose the the strearing so i gota get another outa my parts car hopefuly i didnt mess the threds in the hole up but hopefuly i can get it done afterschool today dont have much to go
ChevelleSSLS6
May 6, 2025 03:00 PM
joeramlowlol
Feb 9, 2014 05:50 PM
GSRcivicGSR
Mar 10, 2004 05:01 PM
Dacalac
Aug 7, 2003 12:00 PM
LudeyKrus
Mar 25, 2003 04:56 AM
