Help with code 21 Try this one please.
Old Aug 10, 2002 | 02:16 PM
DTAYLOR's Avatar
New User
Default Help with code 21 Try this one please.
I just put a ls/vtec in my crx and I keep getting a code 21. I have checked the ohms from the spool soleniod it is at 20 ohms(in factory limit). I have check the wires from the computer to the soleniod (ok). Installed in pin where it plugs into computer. Installed a new ground on the valve cover. I clear the code and as soon as I start the car it comes on. The only thing that I have found is the o-ring where it bolts to the head is cut, could this be my problem?? I have a pr3 computer in a 88 crx. HELP HELP. I would like vtec!!!
Old Aug 10, 2002 | 08:03 PM
psi420's Avatar
Default Re: Help with code 21 Try this one please. (DTAYLOR)
What pin do you have it plugged into?
A08 is the correct pin.
Old Aug 11, 2002 | 05:23 AM
DTAYLOR's Avatar
New User
Default Re: Help with code 21 Try this one please. (psi420)
I have added the wire to A8 plug.
Old Aug 11, 2002 | 12:53 PM
DTAYLOR's Avatar
New User
Help please!!
Old Aug 12, 2002 | 07:23 AM
DTAYLOR's Avatar
New User
help, help
gsrauto98
May 28, 2010 12:04 PM
bobbyeg6
Mar 20, 2010 05:11 AM
ezazzmark
Feb 25, 2003 07:09 AM
