injector issue
Old Feb 24, 2009 | 12:20 PM
92 CIVIC HATCH VX's Avatar
Default injector issue
ok i got a h22 and one of the injectors went out i had to move my car so i used a h23 injector i had is there any long term effects using that injector?
Old Feb 24, 2009 | 12:25 PM
92bb2's Avatar
Default Re: injector issue
yes. It's 240cc versus 345cc. its staying open for as long as the 345cc would stay open but it will not push the same volume in that time span. Get another one before you start getting detonation.
Old Feb 26, 2009 | 04:58 AM
ididdy's Avatar
^^^ X10 very dangerous, that one cylinder is over-heating because it is too lean.
Old Feb 26, 2009 | 06:00 AM
kulrevon's Avatar
That one cylinder is going to be running lean all the time. You might end up with a hole in the piston. I am not sure how much the computer can retard your timing because of the reading from the knock sensor. But I am pretty sure you are losing a decent amount of power also
I would would change the injector ASAP.
Old Feb 26, 2009 | 08:46 AM
will do thanks guys!
totsie7944
Jul 29, 2009 08:36 AM
a1320honda
Sep 23, 2007 01:06 PM
StickyDilJoe
May 6, 2003 02:08 AM
JohnShaft
Sep 5, 2001 02:01 PM
