new figures from the dyno today
well im very pleased . with the mods that i have and with it beiing totally untuned i got onto the dyno today , just for some pulls and mustered up 186.1 whp, and 130.6 ft\lbs. all motor .
it isnt bad for just boltons , motor never broken open for cams or cam gears or anytihng and no vafc.
ill see if i can post the sheet later this week , the curves look bad, but i know the power is there and more can be squeezed out with some fuel tuning
[Modified by itr206, 3:00 PM 8/10/2002]
actual or corrected?
You have a very strong motor if you got that much.
Mine is tuned with a lot more goodeis and has the same numbers
no they are corrected numbers.
i have the jdm 4/1, custom test pipe. apexi n1 catback , aem cai, aem feul rail , aem fpr, walbro 255 lph, msd digital 6 with coil, cap and wires.
i also played with timing and set it to 18 degrees and pulled the ps.
since my last dyno session , i added the ignition stuff, a new cai and the fuel pump and was running 26 degrees for some unknown reason . and only pulled 168.8 or something like that. and running even richer than i am now. i tuned downt he fuel just a bit , but can only do soo much without a vafc
i/h/e test pipe , fuel rail fpr, fuel pump and ignition
again this is untuned with way too much fuel
Good numbers, but we need names of companies man.....
2SlowDC
Nov 22, 2005 06:56 AM
civic_freak
Apr 5, 2004 10:30 AM
USDM 4G VTEC
Aug 23, 2003 08:22 AM
