CEL CODE 21 Fixed!! Now new problem with downpipe and radiator HELP..
Old Feb 24, 2009 | 12:00 PM
honda_fan06's Avatar
Icon2 CEL CODE 21 Fixed!! Now new problem with downpipe and radiator HELP..
ok i have a 96 gsr integra. just got back yesterday from a tune cause its turboed with hondata s300. got on it one time and code 21 came on and it seems that my vtec is cutting on and off. oil level is fine. not sure what to do next. any help? maybe illustrations? Thanks for all your help. Oh yea i can kill the car out and it goes away.
Last edited by honda_fan06; Feb 26, 2009 at 10:13 AM. Reason: Fixed reason and added another!
Old Feb 24, 2009 | 12:18 PM
tylersvols's Avatar
Default Re: CEL CODE 21 Help!
could be your vtec solenoid. make sure the wire is plugged in good both at your solenoid and the ecu.
Old Feb 24, 2009 | 10:24 PM
does anyone have a wiring diagram for vtec?
Old Feb 24, 2009 | 10:38 PM
bonstokLS's Avatar
Leaks? I was told toteplace the cam plug.
Old Feb 25, 2009 | 07:25 AM
tylersvols's Avatar
Old Feb 25, 2009 | 08:41 AM
whitengolddc2's Avatar
Try taking your selonoid apart and cleaning the screen.
Old Feb 25, 2009 | 09:34 AM
thanks for the diagram tylersvols.......and has anyone had this problem b4? what worked for you?
Old Feb 25, 2009 | 11:26 AM
i think i may have found the problem.....i have alot of air bubbles in the cooling system will that cause my vtec to not work?
Old Feb 25, 2009 | 06:14 PM
tylersvols's Avatar
i had the same problem in my 93 teg but it was because i did a swap and i didn't get the pin plugged in good. but since your car came with the gsr i wouldn't think it would be the wiring. see if you can swap with a buddy to see if it's your soleniod. i wouldn't think that your cooling system would have anything to do with you vtec issue. oh and also make sure your reset your ecu.
Old Feb 25, 2009 | 08:18 PM
bonstokLS's Avatar
Make sure that your not leaking any oil. I got a new cam plug but I need to see how that gets installed. If you are leaking, then not enough oil may be adding to the problem.
Old Feb 26, 2009 | 10:12 AM
ok thanks for all the input i did get all the air out of the cooling system and i took my whole vtec assembly apart and cleaned it with carb cleaner now no more issues with vtec. Thanks for all the help and support that you all have offered.
But do have another problem.....My down pipe is too close to my radiator and it is making the car overheat!!!!! has anyone had this issue with the downpipe being too close to the rad and making it overheat? Does anyone have any suggestions or ideas for me to try?
tavo.760
Dec 17, 2013 10:22 AM
newbbb
34
Oct 10, 2008 01:37 AM
TURBO DC2
Jul 17, 2005 06:30 AM
LudeJdm
28
May 29, 2005 09:51 PM
