EK seat fitment help and...
Okay i got a set of integra cloths i wanna put into my 2000 hatchback. I know the fronts will bolt in with 3 bolts.
But what kinda modifying do i need to do for the rears to fit in and be functional?
Is it a straightforward swap?
Also i'm installing a SI cluster that is plug n play correct?
And will the 4dr EK or 99-00 SI coupe rear lip fit on my hatch?
Re: EK seat fitment help and...
the rear seats from the teg won't fit. you will have to do some modifying to the bracket on the bottom and the bottom will need to be taken out of a four door, but won't look so good.
the si cluster will pnp with no problem.
the lip will not work. the coupe/sedan will fit eachother, but the hatch is totally different.
If you want the seats to work, you have to swap the inner rails on the Integra seat with the inner rails from your EK seat.
Thats how I made mine fit.
build_my_hatch
02-21-2011 11:26 PM
4drferio
12-30-2004 06:35 AM
172R42Type16888
10-31-2003 03:48 PM
