90 accord let run 5 hours now having problems
Old Feb 24, 2009 | 10:47 AM
osati's Avatar
New User
Default 90 accord let run 5 hours now having problems
hesitates when given gas. rpm and odom. went out, batt. light on when stopped, off when i go. fine when idling after jumpstart. any ideas?
Old Feb 25, 2009 | 09:46 AM
P_Adams's Avatar
Default Re: 90 accord let run 5 hours now having problems
I'd start by verifying the alternator is operating correctly; not just operating.
At idle, the alternator should be able to sustain a minimum of 13.8 volts, with almost everything on.
If it is the original Alternator, you're probably suffering from worn brushes. As they wear, they loose spring tension and thus contact with the Alternator Rotor. At idle, it may not be charging at all.
P
nanodc2
Nov 21, 2014 11:01 PM
lxaccord51oxl
Jul 25, 2012 06:27 PM
quickster
Jun 24, 2010 10:16 PM
ballerchild
May 21, 2007 02:18 PM
B2AMMO
Mar 9, 2004 07:59 AM
