GSR Timing Belt Tensioner Problem
alright well im in the middle of putting a new head on my integra and the tensioner pulley bolt is stripped. How would i go about getting this off? i cant finish the project without this working properly.
Is the hole stripped or is the bolt stuck in the block stripped. If just the hole is stripped re-tap it. If the bolt is stripped in the block get a flat head screw driver and pry the bolt and you turn the bolt out.
the bolt head is stripped. How would i "pry the bolt" the head of it is flush with the block, there is no where to get any leverage or anything. the motor is still in the car. I'm sure ill figure something out i just need to grab the SOB and go for it.
my **** will finally be running.. dc2 with ls/vtec has been sitting since september, blown head and warped CTR cams :-( so i had to go with GSR cams but i havent been able to drive it since i replaced the head.
Also, try a six point socket if you haven't yet. If there is any shape left to the bolt head you have a better chance grabbing it this way.
If that doesn't work i would try the vise-grip as suggested.
hmm i cant remember what type of socket i have using, i know its a 14mm bolt head. the bolt is on extremely tight for some reason, i havent touched the timing since i've had the car but goddamn.
but i know what you mean, i know i need to replace it. i just wanted to make sure the car started, THEN ill try to mess with the tensioner.
it started up fine, belt was wiggling and rattling against the belt cover, then i opened the throttle and the car died cuz the timing belt slipped off.
well i would replace the belt just for safety. and you should be praying you didnt bend any valves when the belt slipped off...you basically have to redo your timing
I know this is a little old but hey...Bolts strip out on me all the time get those stripped bolt removal sockets at autozone they are cheap too.
clindberg86
29
Jun 26, 2014 08:51 AM
Renegade
15
Sep 22, 2003 06:28 AM
