Stock LS vs LS/VTEC 317whp @9.5psi - AV Engineering Tuned
Old Feb 24, 2009 | 09:24 AM
PrecisionH23a's Avatar
Default Stock LS vs LS/VTEC 317whp @9.5psi - AV Engineering Tuned
I thought I would share this with you guys. Our customer currently had a stock LS with Peak-Boost (t3 57trim) turbo kit and made 267whp @10-11psi. With the addition of a GSR head, ITR Cams, Skunk2 Cam Gears, Edelbrock Victor X manifold, and of course dyno tuning the s300 we picked up a very good bit of horsepower with less boost.
317whp/227tq at 9.5psi. For all the correction factor haters, the 317whp/220tq uncorrected was 306whp SAE. The chart showing 250whp was at 9.5 psi to compare the difference at the same boost pressures. The bottom end of course is bone stock so I did not feel comfortable reving out to 8200rpms which clearly would have kept making power to around 340ish whp.
Old Feb 24, 2009 | 09:28 AM
Schister66's Avatar
Man U FTW
Default Re: Stock LS vs LS/VTEC 317whp @9.5psi - AV Engineering Tuned
That's a pretty substantial gain. Goes to show that VTEC heads really are magic
Old Feb 24, 2009 | 09:31 AM
Vtak ftw! The ITR cams definetely helped out a ton. I also forgot to mention this was on pump gas.
Old Feb 24, 2009 | 09:32 AM
spoolin turbo s's Avatar
goes to show that its not just the vtec, but the entire head and valvetrain are like night and day
Old Feb 24, 2009 | 09:47 AM
Ls_dx's Avatar
Nice numbers. 300 Hp Is really fun on the streets
Old Feb 24, 2009 | 09:53 AM
DOHC_16v's Avatar
Nice numbers/powerband. It's good to see what a proper head/cams can do.
My setup needs 17psi to make the same #s, with more torks of course. Where can I get this Vtak/TypeR for my VW?
Old Feb 24, 2009 | 10:04 AM
a 20v head ported to hell with oversize valves and a solid lifter with a huge cat cam would be very comparable flow wise to a stock f20c head and with the solid lifter kit you could rev to 10,000rpm's maybe 500-1000 more, with the hydraulic lifters you are limited to about 9000 rpms with a good valve train such as supertech
it'll cost you about 6-8k on top of a built 2.0 stroker with the forged crank from the fsi
and there you go
just no one in the vw world will drop the dime to do it, the stuff is made to do just as much or more than Honda's but no one wants to pay to play with the above setup with a cam still on hydraulic lifters and a STOCK AEB head with a t3t67 not sure if it was the HO version or not but 713whp is the most that has been made and that is the most out of a 20v 4 cylinder so far and 615 whp has been made on a 1000cc chip tune with a s362 while only revving to 7500rpms which i think is amazing to make that much power without revving any higher while the 713 was on standalone and revved to 9000 if i remember correctly
i know where a head like this is setting for sale with a supertech valvetrain and would just need a solid lifter conversion and the cams...........and i've seen the flow sheet it flows more than a stock k20 or f20c
pm me if interested its actually a REALLY good price at a very reputable company endyn did it and still has it. some guy dropped it off didn't pay, and never came back. it flows 301cfm max on the flow sheet if i recall correctly
Old Feb 24, 2009 | 10:58 AM
turbo-crx's Avatar
wont the valves dig into the the stock ls pistons with Itr cams? I know my Ctr's did.
Old Feb 24, 2009 | 11:41 AM
DOHC_16v's Avatar
and there you go
I was just joking, but thanks for all the info. I don't have the coin for a SERIOUS setup, and if I did it would be in a RWD or AWD car.
The highest hp 20v is 857whp
Old Feb 25, 2009 | 07:35 AM
92rotteneg's Avatar
good numbers, gotta love the ls/vtec turbo.
Old Feb 25, 2009 | 08:30 AM
That's why checking piston to valve clearance is important.
Old Feb 25, 2009 | 08:45 AM
is that 4 or 5 cyl 20v? and was that gas or alcohol? the one i mentioned was on gas?
also what turbo was that with?
and i hear you about awd or rwd
Old Feb 25, 2009 | 10:14 AM
turbo-crx's Avatar
did you use a thicker hg?
Old Feb 26, 2009 | 03:00 PM
hayn_integra's Avatar
Hey! I know this car!
Old Feb 26, 2009 | 07:01 PM
92redhatch's Avatar
nice.
Old Feb 26, 2009 | 07:12 PM
legomytego's Avatar
i was told you cant get away with itr cams on stock ls/vtecs how do you go about doing it do they have to be advanced or anything ?
Old Feb 27, 2009 | 12:35 AM
blinx9900's Avatar
importtuner did something similar years ago and the addition of the vtec head added 35whp on a turbo B, i think that was on fmu setup too!
Old Feb 27, 2009 | 06:32 AM
You check clearances. We are running a slightly thicker headgasket and were very careful when it came to dialing in the cams on the dyno.
typer161
Feb 15, 2012 03:54 PM
93turbo16
Jun 28, 2005 07:32 AM
redlseg
Jun 24, 2005 06:43 PM
DriveSlowHomie
Jan 26, 2005 08:59 AM
