Boom!
Old Aug 10, 2002 | 01:13 PM
Taloola's Avatar
Default Boom!
can you guys tell em what happened? j/k
[Modified by gokoolFL, 10:13 PM 8/10/2002]
Old Aug 10, 2002 | 01:39 PM
Chiovnidca's Avatar
Default Re: Boom! (gokoolFL)
I hate it when that happens.
Old Aug 10, 2002 | 07:47 PM
CivicEK.PDX's Avatar
what the hell you do?
Old Aug 10, 2002 | 07:50 PM
psi420's Avatar
Ran to lean! Good Job!
Old Aug 10, 2002 | 08:15 PM
acuratech's Avatar
looks like a friends motor when he forgot to tighten his cam gears
Old Aug 11, 2002 | 12:29 AM
Mista Bone's Avatar
D Tranny Guru
broken cam
note the the head is rotated 180 degrees from the engine in the 2 pictures
Old Aug 11, 2002 | 07:29 AM
non-VTEC's Avatar
a little JB weld should fix that up........
Old Aug 11, 2002 | 09:29 AM
DLB1994's Avatar
Default Re: Boom! (non-VTEC)
looks like nitrous damage
Old Aug 11, 2002 | 09:32 AM
DLB1994's Avatar
Default Re: Boom! (DLB1994)
i did it with nitrous
runing lean with to much timing
Old Aug 11, 2002 | 10:29 AM
chasrex's Avatar
nitrous was my guess too, a broken cam probably wouldn't be enough to take out a rod.
Chas
Old Aug 11, 2002 | 10:57 AM
Kamin's Avatar
Default Re: Boom! (chasrex)
bahh! a little hondabond and jg welds youll be FINE
Old Aug 11, 2002 | 12:10 PM
Chiovnidca's Avatar
It looks like it dropped a valve to me. Then they must have driven it until it wouldn't run anymore.
Old Aug 11, 2002 | 01:58 PM
Tweakmeister's Avatar
Default Re: Boom! (Chiovnidca)
holy **** !
Old Aug 11, 2002 | 02:59 PM
IM ALL BOB's Avatar
hey gokool did u use that head that You said was milled 2mm off https://honda-tech.com/zerothread?id=250550#2380786 ? if it was it might the #1 reason your car commited suicide
Old Aug 11, 2002 | 05:41 PM
MooreBoost's Avatar
Default Re: Boom! (IM ALL BOB)
Ouch, what shot are you running? Ducktape! LOL, I wish.
gmoore
Old Aug 11, 2002 | 09:36 PM
BoredNStroked's Avatar
Default Re: Boom! (gmoore379)
Looks like valve to piston contact......too lean melts holes in ****....
Old Aug 11, 2002 | 09:57 PM
FLIPboi's Avatar
Default Re: Boom! (C5_ALLMOTOR)
daym yo im sayin that mess juss all crumbled up yo , yea i say bubble gum will do the trick to fix it all up than and sum duck tape "the machanic's favoret tool "
B's
May 25, 2017 04:04 AM
king-of-the-hill
Feb 4, 2009 02:59 AM
Kicker773
Apr 5, 2005 03:49 PM
JohnBlaze
Feb 20, 2002 05:52 PM
