A Few Questions about Timing
Old Feb 24, 2009 | 07:32 AM
bopbop93030's Avatar
Default A Few Questions about Timing
1. Does the timing affect your MPG?
2. I need a little performance should I move it towards advance or retard?
Thanks!
Old Feb 24, 2009 | 12:33 PM
tamadrummer1120's Avatar
Default Re: A Few Questions about Timing
Yes, timing will affect MPG. If your timing is dead on top dead instead of whatever it should be like 6 degrees before, the idle will be different, possibly too high. Same with distributor timing, if you adjust the distributor, you will affect timing, but can do it a lot easier and in smaller increments, unless you have aftermarket cam gears.
Old Feb 24, 2009 | 02:57 PM
NeKe1point0's Avatar
You will not get the gains your hoping for by adjusting ignition timing.
alperx
Engine Management and Tuning
Jun 7, 2011 05:00 AM
allnaturalb16
21
Aug 14, 2007 08:57 PM
kixcrx
Nov 10, 2006 10:33 AM
98slvrcx
Jul 28, 2002 09:58 PM
OneFastLS
May 25, 2002 03:12 PM
