NEED HELP : oil shooting out from dipstick hole?
Old Feb 24, 2009 | 12:07 AM
G-Sum1's Avatar
Banned
Default NEED HELP : oil shooting out from dipstick hole?
i got a lsvtec in my car for some reason its shooting out oil from my dipstick hole any suggestions?
Old Feb 24, 2009 | 07:41 AM
kingxcore's Avatar
Default Re: NEED HELP : oil shooting out from dipstick hole?
does your car have a pcv valve if so check it. If it is broken it will cause oil pressure to build in the crankcase making it squirt out of anywhere it can find (aka dipstick)
Old Feb 24, 2009 | 08:21 AM
kyden's Avatar
what are you doing for crankcase venting?
Old Feb 24, 2009 | 02:06 PM
G-Sum1's Avatar
Banned
i checked the pcv its good wats crankcase venting?
Old Feb 24, 2009 | 07:51 PM
418whpturboD's Avatar
rings are probobly toast.. does it smoke at all??
Old Feb 24, 2009 | 10:43 PM
G-Sum1's Avatar
Banned
nope no smoke only from burning the oil that came out
Old Feb 25, 2009 | 02:00 AM
92civiceg9gsr's Avatar
Is the windage tray installed in the crankcase lol? No smoke from exhaust means cant have blowby too bad which means the rings are ok.
Old Feb 25, 2009 | 06:53 AM
N1 Andy's Avatar
R.I.P. Andy
I would go back to the crankcase ventilation situation. You should run a breather setup, or at least a good stock pcv valve/black box setup. Search for it, and you will see hundreds of threads on crankcase breather setups.
Old Feb 25, 2009 | 08:11 AM
G-Sum1's Avatar
Banned
think soo? ima look into that weird because my car just started doing this
preludeguy_92
Jun 25, 2005 11:39 AM
Jeff
Apr 30, 2005 04:01 PM
HT Username
19
Apr 14, 2005 01:04 PM
1.8T_EG
Jul 30, 2004 07:31 AM
dra_phantom
Apr 9, 2002 05:04 AM
