What Race Header to use ??
Old Aug 10, 2002 | 12:42 PM
Reddog's Avatar
Default What Race Header to use ??
Can you guys give me some advice or what all motor striaght race header to use and where to go to get it. I want the kind that comes out in front of my front wheel by the one peice. Thanks Guys!!!!!
Old Aug 10, 2002 | 03:25 PM
JDM_DOHC_SiR's Avatar
New User
Default Re: What Race Header to use ?? (Reddogallmtrcrx)
Have you tried to contact ... .
John from HyTech
or
Dave from SMSP ??
these guys do probibally the best headers out there right now..
[Modified by JDM_DOHC_SiR, 9:59 AM 8/11/2002]
Old Aug 10, 2002 | 03:27 PM
Reddog's Avatar
Default Re: What Race Header to use ?? (JDM_DOHC_SiR)
Thanks you got any numbers or webpages?
Old Aug 10, 2002 | 03:56 PM
DLB1994's Avatar
dc sport make a good one to
Old Aug 10, 2002 | 04:12 PM
New User
http://www.hytechexhaust.com/home/content.htm
sorry I don't know if Dave at SMSP has a webs site yet
Old Aug 11, 2002 | 12:56 AM
2.2L EH2's Avatar
How bout ERE's Race header? Does anyone here have them? is it any good?
Old Aug 12, 2002 | 09:33 AM
badCRX's Avatar
New User
Default Re: What Race Header to use ?? (92_B18c5hatch)
I've talked to alot of different people at races and I've heard of so many others that make headers. I've never seen or been able to get good contact info on them.
Only once did I get info from Bisi (low 11 second all motor single cam). He used a place called Import Hook Ups out in Cali somewhere.
Old Aug 14, 2002 | 09:38 AM
Lip's Avatar
Lip
I without question stand by hytech
Old Aug 14, 2002 | 01:39 PM
2.2L EH2's Avatar
Default Re: What Race Header to use ?? (Lip)
Nice! How much did you buy them header for and where?
Old Aug 15, 2002 | 05:02 AM
Lip's Avatar
Lip
the header was made for me by hytech. Price? i don't know. call john at hytech for pricing for something like this.
Old Aug 15, 2002 | 07:42 AM
Austin's Avatar
Here is what the "normal" HyTech drag race header looks like:
Went to a race last weekend and 5 of the 8 cars in the fast 8 class were running HyTech headers...wonder why....
[Modified by Austin, 8:42 AM 8/15/2002]
Old Aug 15, 2002 | 08:00 AM
All Motor Rex's Avatar
Default Re: What Race Header to use ?? (Austin)
Does Hytech make a "street" header? How does it compare with the SMSP header?
Old Aug 15, 2002 | 08:21 AM
Austin's Avatar
Default Re: What Race Header to use ?? (All Motor Rex)
Yes, he does...
Current thread with the exhaust and header:
https://honda-tech.com/zerothread?id=254126
This is my HyTech header after it came back from HPC Coatings:
https://honda-tech.com/zerothread?id=171165
Old Aug 15, 2002 | 12:25 PM
2.2L EH2's Avatar
Do they have a site? what is their phone number?
Old Aug 15, 2002 | 01:18 PM
Austin's Avatar
HyTech Exhaust
he's quite busy...I typically get better response out of sending him an e-mail at hitechexhst@earthlink.net
Phone number is (949) 581-2181
Old Aug 15, 2002 | 04:24 PM
Nobody's Avatar
Default Re: What Race Header to use ?? (badCRX)
I'd listen to What Bisi recommends, his manifold performs very well and is reasonably priced.
Old Aug 15, 2002 | 07:04 PM
lucky's Avatar
bisis now gets his stuff made by a guy in montclair, california. the shop is called Elite motorsports his name is randy, he makes all of bisi's stuff(header, carb intake manifold, rear-end, roll cage, he does really good work. i have one of his headers and it rips, it will perform just as well as the ones from hy-tech
Old Aug 15, 2002 | 07:50 PM
Nobody's Avatar
Default Re: What Race Header to use ?? (lucky)
Old Aug 15, 2002 | 09:43 PM
Reddog's Avatar
Default Re: What Race Header to use ?? (Nobody)
You got a number for Randy
Old Aug 16, 2002 | 02:45 AM
New User
Wow . ..!! Lip I love the "D" shaped mods on the Header
Dave who need's to have John do the same thing for this new header from HyTech
Old Aug 17, 2002 | 04:21 PM
kb58's Avatar
Banned
This is all fine, but I hope some design effort went into these beside great workmanship. What I mean is, how did they decide on tube lengths and diameters? What rpm are these designed for?
Not saying they haven't done their homework, it's just that 99% of the "race" headers out there are marketing BS and very little scientific design...
Old Aug 18, 2002 | 06:16 AM
Lip's Avatar
Lip
Default Re: What Race Header to use ?? (kb58)
alot of effort goes into Hytech's designs. Look at this header...notice its adjustable. I'm not the only tester out there...but i can tell you i tried not only different step designs...i tried different secondary lengths. I tried shortest version, 2" extensions, 4" extensions, 6" extensions, open header, muffler(which is under that megaphone in the pic)on end of header collected into 1, and i tried this megaphone...and i tried these D shaped primaries. I'm not going to divolge what worked best because John has collected alot of research and made the best he can at this time. Its not some generic piece. I love my Toda Products...but when you purchase nearly all the other headers out there....its a generic piece..yes..some much better then others.
btw...i will tell you that the megaphone worked real well and the step design he's using on his headers is a great combo. Also...its expensive *** stainless....not cheap poop and its not mild steel for sure. Also his welding is second to none.
Old Aug 19, 2002 | 03:34 AM
Mista Bone's Avatar
D Tranny Guru
what John and Dave use are old KNOWN info on designing headers.
There is NOT a correctly designed 4-2-1 header for a honda on the market other than theirs, PERIOD! Holley/Airmass might be close, need to go find one.
For a 180 degree header to work, the primarys must be paired in 180 degree CRANK rotation.......
with a firing order of 1-3-4-2 this means 1&3 along with 2&4 get paired. Now expand the firing order..........
1-3-4-<u>2-1-3-4</u>-2 and you see that 1&2 along with 3&4 can be paired with same results.
Worse thing is this info is almost 40 years old!
[Modified by Mista Bone, 7:35 AM 8/19/2002]
[Modified by Mista Bone, 7:36 AM 8/19/2002]
Old Aug 19, 2002 | 11:31 AM
CHEETAH's Avatar
Default Re: What Race Header to use ?? (Mista Bone)
Actually John has found more power which he refuses to disclose how, until he gets it fully patented.
Apparently there are MANY copycats out there and it just pisses him off that he spent money out of his own posket to do R&D and some of his ideas were blatantly copied. Instead he decides to help the good guys who will in term help him, so the man takes time out from his daily business to build my racecar's exhaust system taking every motor spec into account. He sends me an incredible race exhaust system, I fall in love with it, then he tells me, oh throw that away, I have a new design now where I was able to get an EXTRA 15hp !!! now 15hp from an all motor car which is already pushing limits is unheard of ...
Also, feel free to check out his resume of the exhaust systems that he builds, it should be somewhere on his site ... i.e. he recently completed a Mclauren F1 project, that should say somethign by itself.
Greg
Old Aug 19, 2002 | 01:04 PM
badCRX's Avatar
New User
Default Re: What Race Header to use ?? (CHEETAH)
Greg
If you could just throw that one my way, I'd appreciate it!
