fluctuating idle on a civic with a gsr swap...
a couple of days ago my car was throwing code 9... cylinder position sensor and i fixed it today by replacing the defective dizzy. But my car when warmed up the idle fluctuates. Sometimes it doesn't and sometimes it does. It's idling approximately at 1100 rpm when not fluctuating.
I already checked for leaks and everything seems to be fine. Cooling system is fine. PCV is good. I have a skunk2 intake manifold with a SRI that i got it of ebay(no brand). So whats the next procedure? would you guys say FITV and IACV? MAP sensor?
i would certainly start with iacv, fitv, and vaccum lines.
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2Ahow-clean%2A%2A%2A-your-iacv-k-idle-air-control-valve-1575913/
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2A-how-%2A%2A%2A-clean-your-fitv-aka-fast-idle-thermo-valve-1564019/
mustang5.slow
Oct 20, 2007 07:04 PM
Prevail
Feb 26, 2003 05:57 AM
