Can timing cause a knock?
Old Feb 23, 2009 | 11:46 AM
UserX826's Avatar
Default Can timing cause a knock?
I have a knock on a freshly rebuilt y7. I've eliminated the possilbilies that it's a rod knock, spun bearing, or bad rings.
I'm wondering if my timing is off, can it cause a knock?
Old Feb 23, 2009 | 11:47 AM
hoya_10fintec's Avatar
Default Re: Can timing cause a knock?
yes
Old Feb 23, 2009 | 11:48 AM
98vtec's Avatar
moderator emeritus
its called detonation.
Old Feb 23, 2009 | 11:51 AM
UserX826's Avatar
care to explain a bit please? how can it be that far off and still be starting?
Old Feb 23, 2009 | 12:35 PM
timing might not affect much when idling(15~18) unless you start noticing something like missfiring or hick-ups.
It also could be the timing belt being off.
It would help if you be more specific about the symptoms.
Who did the work?
Old Feb 23, 2009 | 12:57 PM
Jdmglenn's Avatar
Retard your timing asap
Old Feb 23, 2009 | 08:58 PM
UserX826's Avatar
Who did the work?
I did the work, other than what had to be done at the machine shop(pistons put on rods, cylinder hone). And yeah it's the first time i've done that much, but i was careful to get everything done right, torqued down to spec, bearings lubed, etc.. Timing I just don't have much experience with in the past. Still quite the newbie.
I have seen some hick-ups..
If there's anything else you need to know let me know.. Not sure what else i could tell you other than what you know.
Old Feb 23, 2009 | 09:01 PM
1grex's Avatar
only happens under load or all the time?
Old Feb 23, 2009 | 09:12 PM
keving85's Avatar
you need to check your timing quick.....
spark knock.... sounds like it to me.... (basically pre-detonates and rattle's the valves)
did you adjust your valves before you started the motor?
kev
Old Feb 23, 2009 | 09:15 PM
JDM EJ2's Avatar
I think its called valve tic. Its when the timing on the valves is off slightly and it gets smacked by the pistons. You gotta make sure to adjust your valves. My brother just blew his Y8 because he beat the **** outta it like a jackass for a solid 40,000 miles (From about 127,000 to 170,000). **** loosens up over time, especially with excessive vibrations due to revving it out. Anyone agree with that theory?
Old Feb 23, 2009 | 09:19 PM
Former User's Avatar
Read this.
Old Feb 23, 2009 | 09:21 PM
JDM EJ2's Avatar
What is it when a piston just touches the valves without bending them? I swear there is something like that...
Old Feb 25, 2009 | 07:54 AM
valve-to-piston slap. B20/vtec with CTR cams could do this. Well, any engine could do this I guess. =P
I would check the timing/timing belt definately first. Do you not have a timing gun?
Old Feb 25, 2009 | 10:22 AM
UserX826's Avatar
all the time
and no. no timing gun.
haven't adjusted the valves.. i'll have to get a gauge and check em out.
I adjusted the timing last night, and I swear to god the knock was very very faint. Let it run for a few minutes, no hick-ups. Lighter knock. Then I cut it off, let it cool off(cracked radiator, haven't put the new one in yet), start it up again and the knock was about back to where it started.
Old Feb 25, 2009 | 10:45 AM
you did all that work and didn't even check the timing or adjusted the valves???
-common mistake for noobs:
Do you know which line is TDC on the crank pulley? no, I'm not being sarcastic.
-take the timing belt cover off and double check and see if you skipped the tooth anywhere THEN get a timing gun and make sure it's within the spec. Make sure the tension on the timing belt is good as well. And reaplace the rad.,fuel filter...
...and go from there...
Old Feb 25, 2009 | 12:15 PM
UserX826's Avatar
thanks for being nice about that haha. Crank pulley only has the two yellow marks. No white mark anywhere. However, now it looks like the belt tension could be the cause of the knocking.. although the cover is off so it's not slapping that. Just one side of the belt is slapping around quite a bit. But i don't know how i could've taken the belt off so many times and put it back on with too much slack on one side that many times. I'll post a video of it tonight.
Old Feb 25, 2009 | 01:39 PM
trustdestruction's Avatar
The belt slapping around is your timing belt tensioner. You either didn't tension it properly or you need a new one.
remember this thread? https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/knocking-w-video-2507013/
when you put the timing belt on, did you use the mark on the oil pump and the marks on the cam gear like you're suppose to and then put the timing belt on?
Old Feb 25, 2009 | 08:51 PM
UserX826's Avatar
remember this thread? https://honda-tech.com/forums/showthread.php?t=2507013
yes. problem in that thread is fixed. and yes.
Old Feb 25, 2009 | 08:53 PM
i think your tensioner is bad then.
Old Feb 26, 2009 | 11:33 AM
Now it sounds like the problem is all in the timing belt (= affecting ignition timing as well).
SEARCH and find out how to tension the T-belt and make sure the tensioner is good like the other guy said(get a new one i you didn't). I could tell you how right now but I want you to search.
let us know
Old Feb 26, 2009 | 11:40 AM
Oh, almost forgot... for you to read timing mark.. you should see 4 marks on the crank pulley:
- <-----TDC
- <-----with a timing gun, this is what you should see.. within those three marks is fine.
..and hopefully you fixed the timing belt problem.. I watched the video.
Old Feb 26, 2009 | 01:44 PM
93wip's Avatar
if the timing is off you need to pull the head and check the valves if the pistons were slapping the valves i can garrantee the they are bent even if they were lightly hitting they arent ment for that
Old Feb 26, 2009 | 03:59 PM
UserX826's Avatar
- <-----TDC
yeah i've read that before.. but mine just has 2 on it somehow.
and the tensioner is new, came in the rebuild kit.
and i'll search on tensioning. thanks for all the help guys. i'll let you know how it goes
Old Feb 26, 2009 | 06:22 PM
This may help:
Old Mar 13, 2009 | 11:10 AM
UserX826's Avatar
So I finally got to fix the timing.. the right way. I took off the crank pulley, took off the belt, lined up the mark on the crank gear with the arrow on the oil pump. I rotated the cam til UP was up, moving everything CCW. I install the belt, loosen the tensioner, turn the crank, tighten the tensioner. No tension in the belt anymore.
Now, the problem seemed that it was just belt slap before right? I figure.. can't be doing that now. It should finally be ready to go.. So I start it.. and hear the horrifically loud knock.
So.. I started with a not so terrible knock, fixed the timing, and now have a pretty terrible knock.. WTF
AnAccordIsForever
May 7, 2009 09:08 AM
AnAccordIsForever
Nov 13, 2007 08:31 AM
sleeperb16a
Nov 19, 2004 07:32 AM
EFGeeSeR
Oct 31, 2003 11:49 AM
toooslow
Apr 24, 2003 04:24 PM
