My EG won't start! HELP!!!
Old Feb 23, 2009 | 11:06 AM
westsideconnect's Avatar
Default My EG won't start! HELP!!!
Hi Guys,
I just bought an EG si yesterday. It has a B20 in it. When I bought the car yesterday, it was starting up and driving just fine. However, when I try to start the car this morning, it won't even crank. Can it be the starter problem? Please help out guys. Your help is much appreciate it. I'm dying to find out what the problem is.
Old Feb 23, 2009 | 11:08 AM
Former User's Avatar
Default Re: My EG won't start! HELP!!!
Have you tested the battery and its connections, including the ground wire in the engine bay.
Old Feb 23, 2009 | 11:49 AM
The battery seems fine. I popped started the car right now and it work. Could it be the starter?
Old Feb 23, 2009 | 11:56 AM
Yeah, it sounds like a starter problem. Check for blown fuses and whether wiring the starter directly to the battery will crank the engine.
Old Feb 23, 2009 | 11:59 AM
68cam's Avatar
if its not crankin at all then it could be the starter relay wire those come loose pretty easy
if cranks but wont start its prolly the ECU fuse check your fuses first
then check battery conections and then the starter and then the alternator i have had this happen to me too
Old Feb 23, 2009 | 02:34 PM
Thanks, guys. I'll check it out and see wassup.
JC95Hatch
Feb 26, 2012 05:04 PM
JDMdb8isO
Feb 6, 2011 12:58 PM
!97ekhatch!
May 28, 2010 05:59 PM
whatcivic
Dec 6, 2005 05:20 PM
tan2
Nov 4, 2002 10:10 AM
