HELP! recently turbo'd gsr integra
Old Feb 23, 2009 | 09:26 AM
94gsr_jdm's Avatar
New User
Default HELP! recently turbo'd gsr integra
I just installed a t3 t4 turbo on my 94gsr swap integra. after completing the installation we started it and ran fine drove it to a friends house for the night tried to start it the next morning its hard to turn over and its also blowing a mean amount of smoke out of the breather on the valve cover. any advice and info is greatly appreciated!!! ps It was driven with care because it had not been tuned yet. right now it has stock injectors and pump. My question is why is it smoking from the head and why is it having trouble turning over if it never had that problem before. HELP PLEASE
Old Feb 23, 2009 | 10:44 AM
sirmugenpower's Avatar
Default Re: HELP! recently turbo'd gsr integra
upgrade your injectors and fuel pump get it tuned it's probably i desprate need of tuning and also did you adjust your timing after you installed the turbo??
Old Feb 23, 2009 | 11:14 AM
94gsr_jdm's Avatar
New User
ya i have the fuel pump for it i was told not to install till were ready to tune but idk bout that. . but no the timing was not adjusted, after i noticed the problems i disconnected the intake line for no chance of boosting but it still wont start and still blows smoke. I will adjust the timing and see what happens.
Old Feb 23, 2009 | 11:20 AM
mRek9R's Avatar
That's never a good sign if there's excessive smoke coming from the breather...is your breather filter drenched in oil or dry? I'd do a quick compression test and lay out the results here.
Old Feb 23, 2009 | 11:23 AM
hopefully you didn't bent a valve...but do a compression test like mrek9r advised and let us know the #'s
Old Feb 23, 2009 | 11:32 AM
94gsr_jdm's Avatar
New User
Will do asap thanx guys!!
Old Feb 23, 2009 | 11:33 AM
94gsr_jdm's Avatar
New User
ps the breather filter is wet with oil not dry.
Old Feb 23, 2009 | 12:17 PM
90turbointegra's Avatar
If compression test comes out good do a leak down test. I had smoke coming from breather on the cover also turned out to be my ringlands cracked real bad
Old Feb 23, 2009 | 07:57 PM
94gsr_jdm's Avatar
New User
k did the compression test numbers were from 4-1 120 115 85! and 115... idk what exactly the compression should be but i know 85 is no FN good at all. next step?
Old Feb 23, 2009 | 08:24 PM
5GVTEC's Avatar
ehh, a healthy motor should all be over 200!!
Old Feb 24, 2009 | 01:16 PM
94gsr_jdm's Avatar
New User
pulled the head valves look fine but my number 2 cylinder that had 85 compression piston was damaged. we have pistons from a b18b1 with lower compression is that a good idea especially for boosting?
Old Feb 24, 2009 | 11:25 PM
dc4-b20's Avatar
you cracked the ring glands on the pistons thats why you had lots of blow by. dont be a cheap **** take 400 $ and put some 8:5:1 forged pistons in there and go .5 over.
btw, ungrade fuel system thats why u ****ed ur ring glands, too much detonation from running lean, ALWAYS UPGRADE MINIMUM a fuel pump. get a walbro 255.
Old Feb 25, 2009 | 01:03 AM
delbert's Avatar
lol wow..back to ripping it apart
Old Feb 25, 2009 | 01:07 AM
Capt. Jimbo McSubipants's Avatar
This is a classic example of people not taking your time and doing it right
you can say it was driven with care....but we all know what happened.....Boost will make a sane man go mad....lol
Old Feb 25, 2009 | 01:10 AM
Jimmy's Avatar
Global Moderator
Reguardless.. Hope you get this thing running again.. I know it must suck to put hard work into something and be so excited only for it to fail..
Goodluck
Old Feb 26, 2009 | 08:29 AM
lsvteg11's Avatar
^^^^ agreed
Old Feb 26, 2009 | 10:28 AM
Schister66's Avatar
Man U FTW
If you dont get the answers you need in this forum, you should post in the Forced Induction forum. I'd move this thread, but it's too long to be of any use there...
Hotel121
May 9, 2011 05:30 PM
macaddict
Jan 28, 2011 05:48 AM
Jdmefsir12
Oct 16, 2010 11:53 AM
