caR wont start after fill up with gas!?
Old Feb 23, 2009 | 07:03 AM
01_ITR's Avatar
Default caR wont start after fill up with gas!?
About two weeks ago i went and put some gas in the car, i went to go start it and it didnt want to start. It finally cranked over on the 2nd or third try. I didnt really think too much of it. I went again to put some gas in last night and it did it again. Didnt start on first try and finally cranked over on second or third try. Weird thing about it is, the car runs great besides this and starts up fine every other time. It only stumbles upon start up when i put new gas in. Anyone have any idea of what could be causing this? I did some research and other people with hondas have the same issue, although no site really diagnosed the problem fully, people mentioned bad gas cap or purge control? Any ideas?
Old Feb 23, 2009 | 11:35 AM
92integraVTECgsr's Avatar
Default Re: caR wont start after fill up with gas!?
I dont know. My 2000 GSR with LS/VTEC does the same thing. Everytime I put gas in it, it won't start unless I pump the gas pedal. If I don't pump the gas pedal, it will just keep cranking over. I think it has something to do with too much gas flooding the system.
I wouldn't think that a bad gas cap could be the cause.
Old Feb 23, 2009 | 11:38 AM
01_ITR's Avatar
^^^well thats the worst thing you can prolly do. Dont pump the gas pedal on any fuel injected system. But still have no clue why this happens...
Old Feb 23, 2009 | 11:40 AM
Petah's Avatar
It has something to do with the evap purge, check that....i remember i had the same problem with my swapped hatch, but i can't remember exact what i did. I think i ended up unhooking it since i was running a JDM ITR ecu that doesn't look for the evap purge system.
Old Feb 23, 2009 | 11:41 AM
If I don't pump the pedal, it won't start. If I pump the pedal 1-2 times when I try to start it, it starts right up. But I have to sit there and keep the revs around 2000 for about 15-20 seconds to burn the excess fuel out, or else it will just stall and die.
Old Feb 23, 2009 | 11:42 AM
Well all my emissions parts are hooked up but I am running Hondata S200. Not sure if that is a problem.
Old Feb 23, 2009 | 12:42 PM
ITR0529's Avatar
Fuel Pump.
Old Feb 23, 2009 | 01:10 PM
Petah's Avatar
Just try unplugging the hose to the evap purge cylinder and see if it starts, if memory serves me correctly, i think that is what i did to fix my problem.
Old Feb 24, 2009 | 04:17 PM
LunchboxZT's Avatar
Try this. Drive you car around and then shut of off. Spend about the same amount of time with it off as you would if you were filling it with gas.
What I think may be going on is it would be a bad fuel pressure regulator, and you are vapor locking your fuel system or it is a drop in fuel pressure where it needs some time to prime age.
Next thing you should try if it dosnt start right up. Just put the key in the ignition to acc II until the fuel pump stops running and try and start the car.
If it starts right up try this whole thing agen. You may just have a bad FPRG.
Old Feb 27, 2009 | 08:30 PM
WheaMyRyceGo's Avatar
Did you ever figure out what was wrong with your car?
Mine does the same thing after EVERY fill up. If I dont have the gas pedal to the floor it WONT start. Then after starting I have to keep the rpms around 2000 for a couple minutes or else itll die again.
Old Feb 27, 2009 | 11:04 PM
SiClone's Avatar
My 99 Si did this exact thing after I swapped out the stock ecu for a chipped p28. It was always an experience waiting to happen when it was fill up time. I swapped the stock ecu back in and no problems.
Old Mar 1, 2009 | 10:11 PM
robfrmny21's Avatar
could be the fuel pump, there is a check valve in side the tank . its with the pump and level assembly. its a check valve that is suppose to hold fuel pressure even when the car is shut off, it is suppose to bleed it off lil by lil.... if that thing goes bad you will end u with extended cranking. but this will be there everytime the car is shut off
Old Mar 24, 2009 | 06:00 PM
Anyone figure it out? Mine is doing it more and more lately, not just after I fill up. It doesn't matter how much gas I have, sometimes it'll do it and sometimes not.
It's really getting annoying having to hold the REV's high for a good 15-20 seconds just to burn off the excess fuel so it won't stall. I am going to try unplugging my EVAP canister and the rest of the emission components one by one until the problem goes away. I have a feel it is something to do with running an OBD1 ECU on an OBD2 car.
Old Mar 25, 2009 | 08:50 AM
MD-Type-R's Avatar
does the same thing happen if you turn your key one or two clicks (same as when you play your radio etc with your car not started) and let the fuel pump prime?
Old Mar 28, 2009 | 05:29 PM
Yeah the same thing happens all the time. I always let my fuel pump prime before I turn the key. I've also tried starting it without letting the fuel pump prime to see if that would make a difference, but still no difference.
Old Mar 28, 2009 | 06:36 PM
Ill let it prime next time. I just filled the car up two days ago and I had to press the gas pedal down to get it to start. Then I still had to hold the rpms for 30 seconds or else it would die. (Turning on the AC) also helps [It makes it idle higher]
Old Apr 2, 2009 | 07:30 PM
This is exactly what is happening to my car. What is your setup?
Old Apr 2, 2009 | 07:50 PM
Beasty18C5's Avatar
I had starting issues a while ago and i trouble shooted my problem. The car would start sometimes and sometimes it wouldn't. The culprit that transmission ground wire over time the screw gets rusted and on top its over a pianted surface so looses resistance. I made a new strap and ran it right to the battery ground and now car starts every time. And i know that was the problem for sure with my case. A friend of mine also integra owner had the same issue
Old Apr 2, 2009 | 07:54 PM
hybrid21's Avatar
Its one of the hoses on the evap purge it happened to mine and i fixed it. Don't ask which one because this was a year ago and I no longer have the car to remember.
Old Apr 4, 2009 | 05:31 AM
mathieucivic's Avatar
Simple trouble guy!
When you put gaz the purge solenoid stay open and the intake minifild fill with some liquid gaz or vapour.
If your car is OBD2 you need to hook-up the system like OBD2 and invert the solenoid control in your chipping setting. Or use a OBD1 charcoal canister and purge solenoide.
For JDM engine, the system use a king of ventury on the throttle body and no purge solenoide. This way you need to use a charcoal canister desing for this purpose.
If you don't hook-up the canister to the engine, it may fill up in ome time and spill gaz to the outside, the ground or a hot part in the engine bay and catch on fire!
Old Apr 5, 2009 | 07:55 PM
Originally Posted by mathieucivic
Simple trouble guy!
So you're saying all I have to do is invert the solenoid control through my Hondata S200 if all my OBD2 is hooked up correctly which it is.
menappi
Jun 21, 2006 04:01 PM
LvN
Jun 9, 2006 11:31 AM
StraightCivic
May 15, 2006 05:07 AM
pr0digy1
May 8, 2002 09:08 AM
