help with f22b1 vtec
Old Feb 23, 2009 | 04:10 AM
oj5joker's Avatar
Default help with f22b1 vtec
I want to get more horsepower out of this engine without boosting I've got headers and I'm goin to port out the heads what else can I do to increase horepower cuz other than that I put a cold air intake and a lil custom cat back exhaust suggestions will be greatly appreciated
Old Feb 23, 2009 | 04:24 AM
GhostAccord's Avatar
Default Re: help with f22b1 vtec
Maybe a cam, higher compression pistons, sleeve and overbore the cylinders, stroker crank..... The possibilities are pretty much endless. What is your budget and what are your Hp goals for the car. What are you building the engine for, Is it for Drag, Street Track or just daily driver?
Old Feb 23, 2009 | 04:41 AM
oj5joker's Avatar
its going to be a daily driver i jus want to pull more hp out of it but i dont think im going to bore the cylinder walls makes it wear out faster cuz u make it thinner but wut kind of cam shuld i get?
Old Feb 23, 2009 | 04:56 AM
No it will not wear faster at all. But if your not into going that far that's cool. If all your looking at doing is a mild port, intake and exhaust you may want to look into a Bisimoto engineering cam. You won't need anything more than his Level 2. Bisi Level 2. A Chipped ECU or standalone EMS (AEM, Motec) and a tune will also be required.
Old Feb 23, 2009 | 05:30 AM
oj5joker's Avatar
ok thanks becuz i will have my engine apart soon so i might jus look into boring iit out
Old Feb 23, 2009 | 06:23 PM
BlUAc's Avatar
on my f22b1 head i had it milled a 30ths with a 3 angle valve cut an a aem adjustible cam gear and it was nice a lil more hp gain for 250
Jiggawatt
Jan 7, 2011 11:36 AM
crispchris
Dec 16, 2008 02:42 PM
broketuner-Sol_Si
Feb 2, 2006 08:50 PM
k2civic
Dec 11, 2003 08:55 AM
DaDaShT
Apr 3, 2003 06:40 AM
