Which intake manifold for my setup? (B16 setup inside) Valve Springs needed?
Old Feb 23, 2009 | 03:54 AM
ex96vtec's Avatar
Default Which intake manifold for my setup? (B16 setup inside) Valve Springs needed?
Specs Currently:
2000 B16A2 stock block and head
Ebay header modified to 2.5" collector
2.5" exhaust header back to a dual pass a la mugen muffler no cat
AEM cold air intake
Integra type R intake manifold
Current plan:
Integra Type R cams, Possibly ITR valve springs, UGR cam gears, P28 with s100 and a tune.
Now to my questions..
1st question: I have an Edlebrock Victor X manifold that was purchased for a turbo b16 awhile ago that was since sold. Would I benefit to swap this manifold with the ITR one that is currently installed before I get the car tuned?
2nd Question: Should I install purchase valve springs for when I install the cams?
Old Feb 23, 2009 | 04:09 AM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: Which intake manifold for my setup? (B16 setup inside) Valve Springs needed?
1) no leave the ITR manifold on the motor.
2) yes, install new valve springs. You can get them from James at IPG http://ipg-supertech.com/ for about $140.
Old Feb 23, 2009 | 05:48 AM
ex96vtec's Avatar
1) I am assuming because it has longer runners as opposed to the shorter victor x runners, correct?
2) Should I just do springs? Or keepers and retainers as well? I am assuming that if I get them from James they will be supertech springs and not stockers correct?
Thanks for the reply.
Old Feb 23, 2009 | 06:43 AM
mar778c's Avatar
Community Builder
1) Yes
2) Yes, you can do just the springs and use your OEM retainers and keepers.
Old Feb 23, 2009 | 07:13 AM
ex96vtec's Avatar
1) Yes
Thank you sir. With this combo I should be ok revving to where the ITR cams stop making power correct?
Old Feb 23, 2009 | 07:21 AM
mar778c's Avatar
Community Builder
Absolutely.
Old Feb 23, 2009 | 07:28 AM
ex96vtec's Avatar
Absolutely.
Thank you very much, you have been most helpful.
Rep for you.
Mods feel free to kill it.
92integraVTECgsr
Dec 29, 2020 09:15 PM
LS-VTEC-TURBO-EF9
Jul 16, 2012 03:26 PM
crxfreak1117
Jan 20, 2011 05:04 AM
1SloNeon
15
Nov 13, 2008 09:45 AM
SioneSi
Apr 26, 2002 06:27 PM
