need help deciding on engines
Old Feb 23, 2009 | 02:44 AM
jorge59la's Avatar
Default need help deciding on engines
i have a gsr engine i need to fix. not sure what to do.
fix the b18? spun rod bearing. will cost me about 1000 to fix engine. will put stock parts not forged and put turbo back on.
or swap it with a b20 and go back to all motor with the b20?
if i go na with either engine, which is better?
can i go back to na with:
440 inj.
full 3'' exhaust
stage 4 clutch
255 fuel pump???
installed already
on my car
what to do?
Old Feb 23, 2009 | 02:56 AM
northemt88's Avatar
Default Re: need help deciding on engines
you could pick up an ls or b20 for about 400 and boost that
Old Feb 23, 2009 | 03:10 AM
weavertime1's Avatar
Are you planning to go B20 Vtec (use your GSR head)?
Old Feb 23, 2009 | 04:36 AM
94_Teggy's Avatar
cant you get a gsr block for cheap then 1000 lol..then you can get couple hundred for the bare gsr block
Old Feb 23, 2009 | 06:59 AM
Should def.be able to...unfortunately there are so many tricksters on Honda-tech and the like that I wouldn't buy one unless I heard it running and then tore it down myself. I do commonly see longblocks for less than $1500 though.
Old Feb 25, 2009 | 04:25 PM
jorge59la's Avatar
well i thought B20's were not reliable stock sleeves as compared to B18?
yes i am!
with a b20 can i use same, intake manifold, exhaust, pulleys, etc?
Old Feb 27, 2009 | 11:02 AM
jorge59la's Avatar
Old Feb 27, 2009 | 11:38 AM
hmoobhero's Avatar
if you're going NA and planning to stay NA then either blocks is fine and you can use the parts you already have...
but i would prefer the b20 because it has more torque. depends on what you wanna do. your money...do watever you wanna do...
Old Feb 27, 2009 | 12:10 PM
ALLxMOTOR EG's Avatar
Vietnamese!
Rebuild the gsr with internals work
CW teg
Jun 24, 2010 10:51 AM
jorge59la
Nov 26, 2008 05:24 PM
viet1337
Apr 10, 2007 09:51 PM
xstalkrx
Oct 1, 2003 06:00 PM
