Sway bar
It'll fit with no problem. You won't even have to worry about subframe tearout.
You will need lower control arms though. Your stockers didn't come with the holes for the end links to bolt into. If you can get the arms off an integra or an eg that had a sway bar.
Good luck!
Good luck!
g2b2
May 6, 2007 04:16 AM
