ls/v turbo questions
Old Feb 22, 2009 | 10:10 PM
vx-c.l.b.a's Avatar
New User
Default ls/v turbo questions
Came to a huge stop on my project do to questions
What headgaskets are good to use for turbo set-ups??
What kind of pistons/rods to use?? Ani strocker kits??
Would a gt30r be enuff??
looking to make 450-500 on a blockguard.. if that's posible.
Gsr head.crower valve spring retainers/victor x mani
what size injectors to use. would 550 be enuff??
what cams are best for boost??
Old Feb 23, 2009 | 06:37 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: ls/v turbo questions
a search will net you results. but im bored so ill answer these questions.
stock gasket is fine, i use cometic, and havent had an issue, others use golden eagle.
no stroker kits many of the big dogs use a stock crank im using carrillo/cp
should be but there are people better suited to answer that question.
leave the block guard out its old tech.
no 750's.
i made 540 on gsr cams in a b16. i like the IPG v1 cams im running now.
Old Feb 23, 2009 | 06:41 AM
Schister66's Avatar
Man U FTW
1. OEM Headgasket
2. Eagle/CP or Wiseco....the only stroker i would ever advise is an LS crank...nothing more
3. The GT30r would be a decent turbo for your setup, but there are others out there. One to consider is the Borg Warner S256.
4. Ditch the block guard and run stock sleeves unsupported.
5. The GSR head with the modifications listed will be fine for your power goal.
6. For your goals, i would go with a set of 880cc injectors. 750s may be large enough, but i'd play it safe and go a hair larger
7. The stock GSR cams aren't bad, but a set of ITR cams or Blox B's would work nicely for your setup
Old Feb 23, 2009 | 10:46 AM
vx-c.l.b.a's Avatar
New User
So oem and cometic are good for h.g
Why is it beter to leave the block guard to the side and not put it on??
Also are the arias piston/rod kit any good???
u_tal
May 17, 2020 08:34 AM
vipcivic
Dec 7, 2008 11:23 PM
Kfeddy
Aug 6, 2007 06:36 PM
0ptimus prime
Oct 7, 2004 09:33 AM
