90-91 Civic EX knuckles with DC calipers on a CRX. Axle prob..
Old Feb 22, 2009 | 09:12 PM
akandok's Avatar
Default 90-91 Civic EX knuckles with DC calipers on a CRX. Axle prob..
Here we go again. I just had issues with breaking some axles with DC knuckles and ebay engine mounts. This is in a 88 CRX Si with a B18A1 swap.
I recently changed over to the Civic EX knuckles and kept the DC knuckles. Everything bolted up nicely. Then I swapped the old engine mounts for brand new Innovative mounts. When I lowered the car I noticed that the axles are wayy to close to the strut forks. I moved the car from one house to another, about 15 miles. And I think the axles do touch the forks at some point.
Now the car is being stripped to make it lighter and maybe do a small wire tuck... New engine and tranny.. BUT I also need to address this issue. Anyone have any ideas? Anyone else can post pics of their set up?
here is a link to all the pics
https://honda-tech.com/forums/appearance-build-threads-122/bad-economy-empty-pockets-crx-build-thread-2495266/
Old Feb 22, 2009 | 09:13 PM
akandok's Avatar
Default Re: 90-91 Civic EX knuckles with DC calipers on a CRX. Axle prob..
I will link a few pics
Old Feb 24, 2009 | 07:34 PM
akandok's Avatar
anyone?
Where is Tyson when you need him?
Old Feb 24, 2009 | 08:49 PM
dcvt16's Avatar
i had a simular problem after a b swap with the old place racing mounts. i ended up using shock forks from the EF SIR. the shock fork has more of a bend in the side that is rubbing on your set up. but still allows you the use the EF shocks. Search for some pics and info on the EF8/9 shock forks and you'll see what i mean.
Old Feb 24, 2009 | 09:50 PM
akandok's Avatar
Yeah,
Search function on this site is down, and still sucks.. So unfortunately I cant search.. But I will look into the SIR forks..
Old Feb 24, 2009 | 11:16 PM
MOE@Hyper16Valve's Avatar
Icon7 Re: 90-91 Civic EX knuckles with DC calipers on a CRX. Axle prob..
The bushings for the lower part of the fork LOOK old replace those then see how close the axle is,They look cracked the weight of the motor might push it forward or back...
Old Feb 25, 2009 | 03:54 PM
dcvt16's Avatar
Originally Posted by akandok
Yeah,
you can do a search on google as well and come up wih good results..
i bought some EG coilovers from someone once who had them on an EF with a b series and the shock forks(EG) were ground down to prevent rubbing, but it didn't seem safe and i dont recomend it.
Old Feb 25, 2009 | 04:02 PM
88Hatchy's Avatar
check the radius rod bushings. they might cause the whole assembly to sit too far back.
Old Feb 26, 2009 | 06:59 PM
akandok's Avatar
still need help..
Bushings still would not push the fork that close to the axle... Axle has to be in the middle
Old Mar 1, 2009 | 08:27 AM
akandok's Avatar
still need help
Old Mar 1, 2009 | 08:45 AM
iskate2's Avatar
just a shot in the dark, but are you sure those are the correct shock forks for the car? im not certain about how modular that part is between different chassis, but its worth a shot...
Old Mar 1, 2009 | 11:41 AM
akandok's Avatar
Original forks.
Anyone that has done this swap? Tried google, everyone talks about doing it, but noone gets it done..
Old Mar 1, 2009 | 01:38 PM
CW-ITR's Avatar
My same set up is on hold waiting for new bearings to be pressed in. i'll check back to this post to learn more about the solusion.
Old Mar 1, 2009 | 04:23 PM
Crx Jimmy's Avatar
use 90-93 integra forks. They fit the stock shocks and have a larger hump. You can even change the axle with the da forks still on. It's large enough to fit through. It will give much more clearance.
Old Mar 1, 2009 | 04:35 PM
akandok's Avatar
Theres an idea. Will look into that on monday
djnikko
Apr 22, 2010 12:17 PM
SlowMotion
May 26, 2007 11:09 AM
christion
Apr 9, 2007 04:06 PM
redlinepulse84
May 19, 2004 01:11 PM
DEVIN22CBR
22
Dec 13, 2003 08:42 PM
