Honda Accord 2002 Center Console Removal
Old Feb 22, 2009 | 08:48 PM
kikitheexplorer's Avatar
New User
Default Honda Accord 2002 Center Console Removal
I need help removing the center console cover on a Honda Accord LX 2002.
I dropped an earring inside the console where the parking brake is. There are
4 screws. I was able to remove 3 screws, but the screw on the drivers side, closest to the front, I can't get at because of the seat. Please advise. kikitheexplorer@yahoo.com
Old Feb 23, 2009 | 01:29 AM
xpragmaticx's Avatar
New User
Default Re: Honda Accord 2002 Center Console Removal
You should be able to remove the cup holder without taking any screws out. It just pops right out. I have a stick, but that whole black piece will then pop up also. The boot is still on the stick but I can then just lift the whole black cover over the e-brake and rotate it 90 degrees to gain access to underneath.
Old Feb 23, 2009 | 06:25 AM
redbull-1's Avatar
Here is a guide:
http://www.ledautomotive.com/HowToGu...erLEDHowTo.asp
Old Feb 23, 2009 | 06:29 AM
redbull-1's Avatar
If moving the seat doesn't allow you to access the screw, use an offset screwdriver.
Old Feb 23, 2009 | 08:13 AM
New User
Bless you. I knew it would be something easier. As usual my brain was making it harder than it had to be.
oohtruck
Feb 6, 2016 04:33 AM
sportlead
Sep 4, 2008 05:16 AM
mgalpy
May 13, 2007 07:41 PM
mpxs20
Jul 18, 2005 02:52 PM
crx_ef8
Sep 6, 2003 06:08 PM
