99 civic ex no start problem
Old Feb 22, 2009 | 07:27 PM
jonessw20's Avatar
Default 99 civic ex no start problem
My friend has a 99 civic ex that will not start. He took it to a small time mechanic. and he said that the fuel pressure is at around 90 psi while trying to start. Normaly it should be in the 30 psi range. This is all he could find and recomended takin it to a dealer to get it looked at cause he didnt want to dig any further.
I was just wondering if anyone has any suggestions on what this could be or have had this problem before?
If you need more info let me know, otherwise any input is appreciated.
Old Feb 23, 2009 | 09:45 AM
jonessw20's Avatar
Default Re: 99 civic ex no start problem
nobody has any ideas?
Old Feb 23, 2009 | 09:50 AM
Former User's Avatar
I'd wonder whether the mechanic made an incorrect fuel pressure reading.
Key questions to consider:
Is the CEL ON? Does the fuel pump prime? Is there spark at the plugs? Did the timing belt slip? Is the cylinder compression low?
Old Feb 23, 2009 | 11:17 AM
jonessw20's Avatar
yeah i can't think of anything that would cause the fuel pressure to nearly triple.
It has spark but we couldnt check for codes.
It was running fine and then one day it just wouldnt start.
Old Feb 23, 2009 | 11:50 AM
UserX826's Avatar
What do you mean you couldn't check for codes? Is the light on?
Old Feb 23, 2009 | 05:33 PM
jonessw20's Avatar
Didnt have a scan tool. and also i would assume the mechanic would of been able to check for codes and would have mentioned what they were. but i don't have all the details i only looked over it briefly.
Just trying to get some ideas to help my buddy out.
Thanks for the replies though
Old Feb 23, 2009 | 05:48 PM
slimjimming6688's Avatar
well, atleast you know you have fuel. now DO YOU HAVE SPARK? and also check your FUEL REGULATOR VACUME HOSE and other hoses like vac brake booster n cruse controle
Old Feb 23, 2009 | 06:01 PM
jonessw20's Avatar
Yes it does have spark. the mechanic said the fuel pressure is so high that its just flooding the engine out when its trying to start. I wanted to know if anyone might have an idea why the fuel pressure would rise so high. If the vacuum lines had a leak wouldn't this cause fuel pressure to drop. I wonder if a vacuum line that was plugged or pinched would cause it to raise higher?
Old Feb 23, 2009 | 06:07 PM
does it turn off when you put it in the run position, you can heare it, if its on all the time that could happen or your fuel regulator could be stuck closed
hcontreras
Dec 27, 2015 02:29 PM
bgamera
Aug 14, 2014 12:20 AM
datsol94
32
Mar 4, 2013 04:52 PM
pinoyboy204
19
Mar 9, 2010 09:47 AM
drummr6
Sep 5, 2007 05:43 PM
