H2B type S from down under * Australia
Old Feb 22, 2009 | 06:10 PM
benson03's Avatar
Default H2B type S from down under * Australia
Hi guys,
Just want to share a completed project from a friend. Got it running and tuned last weeked.
JDM H22a Type S motor
Euro R manifold
70mm Skunk2 manifold
Vtec Kidd modified header
3inch exhaust system
Remove balance shafts
Evolution kit (stock innovative mounts)
4.7 ITR box
3inch intake pipe and blox filter
Crome ECU
Car made 150kw which is around 200hp on a dynodynamics (around 220-235hp in yanks dyno)
In comparison to a k24, it made the same amount of torque (200lbs)
Very happy with the number output. The car drives really well. Stay tuned for 1/4 mile results. Going to be running on some slicks to put the power down. hopefully for some 12sec passes
Ill get some pics up of the dyno graph and car set-up
Old Feb 22, 2009 | 07:20 PM
Rob_O's Avatar
Default Re: H2B type S from down under * Australia
That torque number sounds waaaaaaaay high, maybe it's a dynodynamics thing
My engine build will be almost identical to what you've done, gotta go with what works!
Did you do the tune?
Old Feb 22, 2009 | 07:38 PM
Pinho's Avatar
nice set up...should run 12's easy
Old Feb 23, 2009 | 03:37 AM
benson03's Avatar
uncle dave did the tune
Yeh its unbelievable to drive
Old Feb 23, 2009 | 05:28 AM
2fastGSR's Avatar
King of the One Liners
Skunk2 and a Euro R manifolds at the same time huh ?
Old Feb 23, 2009 | 05:34 AM
JDM JEFFREY's Avatar
man u got to it befor me....lol
Old Feb 23, 2009 | 05:40 AM
keemosaki's Avatar
Ya know what he ment...
Originally Posted by benson03
Hi guys,
70mm Skunk2 Throttle body
Old Feb 23, 2009 | 06:10 AM
2fastGSR's Avatar
Of course. . .
Hence the . . . . . .
Old Feb 23, 2009 | 09:04 AM
Rob_O's Avatar
That's how he's making big power!!!
Old Feb 23, 2009 | 12:17 PM
benson03's Avatar
oh yeh sorry guys, its 70mm throttle body
Old Feb 25, 2009 | 03:00 AM
benson03's Avatar
Update: Car ran down the 1/4 mile tonight
Ran a best of 12.8@108mph
Old Feb 25, 2009 | 11:50 AM
MassScene's Avatar
I Have a similar setup ....cant wait to have it in + tune..! What car is this swap in + weight of car 2....??
92-95 JDM H22
H22 Type-S cams
Stock valvetrain "for now"
intake manifold is a re-worked oem h22 manifold...can be seen here @ https://honda-tech.com/forums/showthread.php?p=36574436
77mm-70mm DH-Racing Throttle body
550cc precision injectors
3-3.5" velocity stacked intake
RMF H2B header w/3" 3 bolt flange style
3" full exhaust all mandrel bent steel straight piping to a Flowmaster style turbo muffler
QSD H2B kit
Exedy Twin Disc Clutch
98 USDM ITR tranny w/ OEM 4.7 Final Drive
FULL RACE Traction Bar
Hondata s300
AEM Wideband
Old Feb 25, 2009 | 12:35 PM
benson03's Avatar
sounds like a sweet set-up
Should be looking above the 200hp mark and 12's down the 1/4mile
Good luck with it
Old Feb 25, 2009 | 12:50 PM
MassScene's Avatar
What car is your setup in...? And whats the weight of it ?
Old Feb 25, 2009 | 08:46 PM
NAEGH22's Avatar
wheres the pics man
Old Feb 26, 2009 | 03:03 AM
benson03's Avatar
Set-up is in a EG chasis
Weighs around the 970-990kg at the drags without driver. Looking at around 1060 with driver.
Pics will be uploaded soon
Old Feb 26, 2009 | 04:09 AM
hondatec1's Avatar
pics pics pics
roycivic92
Nov 27, 2012 01:42 AM
DC5mike
10
Apr 7, 2008 07:30 PM
BolivianFuego
20
Jun 8, 2007 10:53 AM
Smoke_em
Mar 9, 2006 08:55 AM
MiKeAhOwSkI
28
May 1, 2005 11:34 PM
