removing climate control trim
Old Feb 22, 2009 | 04:54 PM
turboedsupe's Avatar
Default removing climate control trim
Do i have to remove the dash to take the plastic surrounding piece off? It seems as if there is screws holding it on from the back
Old Feb 22, 2009 | 05:02 PM
94EG8's Avatar
Seagull Management
Default Re: removing climate control trim
Some vehicle info would really help here. Civic, Del Sol, year?
Old Feb 22, 2009 | 05:43 PM
g0ofy's Avatar
if its a civic eg or ej then yeah u would have too.
Old Feb 22, 2009 | 05:44 PM
gsrauto98's Avatar
Agreed. Cant help ya without any info.
Old Feb 22, 2009 | 06:20 PM
its a eg
Old Feb 22, 2009 | 08:49 PM
94jdmeg6civic's Avatar
yes you do have to take out the dash its not that bad its like 8 screws on the backside
Old Feb 23, 2009 | 05:36 AM
94EG8's Avatar
Seagull Management
Edit, nevermind. I thought the OP was trying to remove the climate control, not the surrounding bezel.
Old Feb 23, 2009 | 04:46 PM
I took all that out and there is one screw thats through the back to the right of the steering wheels that i cant get to. I tried a l screw driver and got a couple turns but it would be impossible to put back in
Old Feb 23, 2009 | 06:58 PM
joelmatt89's Avatar
i have done it before yes it sucks, you gotta pull out all the old tricks like Vaseline on the screw driver to hold the screw on there, i don't know what they were thinkin when they designed it like that.It is possible but if you don't want to you may find leaving that screw off makes very little difference when i first got my car the screw wasn't there and i couldn't tell at all until i took it off and noticed it had a hole there
Brake_Check
Dec 18, 2013 10:29 AM
polyhonda
Jan 21, 2013 05:33 PM
mrmckie
Sep 21, 2006 01:44 PM
UNKNOWN_MEMBER
Jan 3, 2006 10:03 AM
coupeuk
Sep 13, 2003 01:17 AM
