accord vibration
If it's a metallic rattle coming from underneath the car, it's probably a rusted or loose exhaust heat shield. Typically the shields around the catalytic converter are the culprit. Poke around under there when the car has cooled and see if anything is loose.
Exhaust shields can be secured with a large hose clamp, or removed altogether. They aren't critical to the operation of the car; they are mainly intended to prevent fires when parking in high grass or other flammable materials.
i already have a large hose clamp on the shield , she's pretty secure. its not that type of rattle. its more like pedal , wheele, vibration. its not like a light vibration. ???????
Have you tried getting an alignment done? My Accord vibrates at highway speeds, and vibrates really bad during braking at high speeds. I have ordered replacement rotors and will get a front end alignment as soon as I put them on.
It might be the heat shield, like the other guy said. Currently, the heat shield underneath my Civic is starting to come loose, and it rattles during acceleration intermittently, and sometimes even hits the shift linkage, which I can feel. Removing this shield won't really make a difference, I did it when I replaced the shifter on my old Integra with a B&M stainless steel shifter and metal shiftknob, and it never conducted enough heat to cause an increase in the temperature of the shifter, which is what I was afraid of.
thanx alot 4 tha info........i checked the shield..my clamp is tight & shes not rattleing at all. + i know what that rattle sounds like .any way. how would i check the inner cv's...pick up the car & move the wheele left to right to see if theres 2much play??up & down would be the ball joints ( control Arms and knuckles??)??would that cause a pretty harsh vibration pulling of from a stop? then the noisse/vibration goes away........??
A bad inner CV joint will vibrate on acceleration (as opposed to a bad outer CV, which will make clicking noises through turns). Check the inner CV boots on the axles to make sure they aren't torn or leaking.
Other than that, it's tough to say. Could be engine mounts. What year and model is it?
hey guyz....??question?? would a busted pcv hose cause a stink *** oil burning smell..
i was messin with my pcv valve the other day & i cracked the old brittle hose............lazinesss..........i havent replaced it..my car is smokin at the tail slightly & a slight oil burnin smell.???i might be over analyzin & the smell was there before but just a thought .im gettin a new hose in a couple hours ill be back on............ps i know the valves need adjustment /seals/ rings replaced.../// 100,000+ miles..im gonna throw on a new t belt & water pump with new cam & crank seals. just for sake of high mailage..............still havent figured my vibration..lol
wawan
May 6, 2016 01:48 PM
fleetw00d
Nov 18, 2010 03:46 PM
YeuEmMaiMai
Jul 6, 2002 03:39 PM
