h22, stock pistons aftermakket rods, what needs to be done?
Old Aug 10, 2002 | 08:07 AM
fastludeh22's Avatar
Default h22, stock pistons aftermakket rods, what needs to be done?
ive heard that some pistions need to be moddedd some way to accept aftermarket rods, what needs to be don to an h22a1?
Old Aug 10, 2002 | 10:44 AM
DLB1994's Avatar
Default Re: h22, stock pistons aftermakket rods, what needs to be done? (93ludevtec)
i cant run a aftermarket rod with a stock pistons the pistons are the weak link the stock rods will hold 350-400whp
Old Aug 12, 2002 | 01:15 AM
aeolus's Avatar
the type s piston might fit on some aftermarket rods,since they are made to accept a floating wrist pin.Maybe youll have to have the rods custom made to fit the wrist pin diameter.
Old Aug 12, 2002 | 07:55 AM
2point6's Avatar
Default Re: h22, stock pistons aftermakket rods, what needs to be done? (aeolus)
why would you do this?
Old Aug 12, 2002 | 04:51 PM
migo's Avatar
New User
Default Re: h22, stock pistons aftermakket rods, what needs to be done? (2point6)
I had Type S pistons on Eagle Rods, No problem
Old Aug 12, 2002 | 11:48 PM
DLB1994's Avatar
Default Re: h22, stock pistons aftermakket rods, what needs to be done? (D.SPECS)
but why its still a cast pistons
Old Aug 13, 2002 | 06:22 AM
bgod's Avatar
Default Re: h22, stock pistons aftermakket rods, what needs to be done? (DLB1994)
this is an absolute waste of time and money.
if yoiu plan to go fi, the pistons/ringlands will go before the rods have any hint of wear.
if you're going all motor, a stock honda rod will easily handle anything you throw at it.
Old Aug 13, 2002 | 07:00 AM
Default Re: h22, stock pistons aftermakket rods, what needs to be done? (bgod)
ok thanks for the info, i was previously missed informed that the rods were the weak link, but after a few different posts ive gathered its the ringlands.
707the89fu
Aug 29, 2014 06:30 PM
turbo-crx
Apr 18, 2008 09:08 AM
nema741
Nov 11, 2003 07:47 AM
98civicEX
Aug 19, 2002 02:58 AM
KRiS1
Jul 29, 2002 01:56 PM
