leaking oil on tranny side from the HG
So I recently had my head resurfaced on my b18c1 due to it leaking oil on the from around the headgasket right above the engine block code and I get my car back and now it's still leaking oil from the same place... what can be done to correct this problem?
Yea and nothing was wrong i've replaced all the gaskets and seals.. The oil is coming from under the HG .. I do not know if it overheated on them but it started overheating the other day b/c my radiator cap went bad but i replaced it and no problems since
It could be a possible culprit depending on how bad/how long it overheated for.
nah i know it's not since that was almost a month after having the hg replaced.... I just want to know what can be done to correct the problem?
Heres this,
https://honda-tech.com/forums/showth...ead+oil+gasket
and if you search "oil leak head gasket" or just "oil leak" you'll find more.
Now I didnt mention this before, but I think I have that same leak as you've described (above/around the HG & blockcode stamp). Turns out this is a pretty common leak.Mines been leaking oil in this same area for a little while now, although I knew sooner or later the leak would point to it's origin. In the mean while I've double checked
* VTEC solenoid gasket (Fine, no leaks here).
* Ex cam cap (Fine, no leaks here. All brand new)
* HG (Brand new, works like a charm. No coolant problems or colored smoke + the head was resurfaced also).
However, after taking a real-close examination of the head again (and after reading a few more post's on this type of leak, just tonight) I found it. It appears to be coming from the distributor which means its more than likely the dizzy o-ring (in my case).
Worth looking into, I got my dizzy new from Distributor King so it wasnt exactly OEM.
that sounds like a good idea ... that is probably the only seal/gasket that has been neglected to be changed i will look into it this weekend
Picked up an o-ring from the dealership today, so i'll keep you posted on my results after I get around to changing it tomorrow.
I have the same problem on my gsr right now, at first I baught a new cam cap thinking that was the problem.... but soon realized that it was the O-ring as well.
- ap
- ap
