tilton valve question if you dont mind
Old Feb 22, 2009 | 03:36 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default tilton valve question if you dont mind
i have my tilton flow valve on the way, and if summits time line is anywhere near correct, it will be on 3-6. cutting it close for an event id like to make.
my question is if anyone minds divulging information, what orifice is everyone using?
Old Feb 22, 2009 | 03:39 PM
Innes's Avatar
Default Re: tilton valve question if you dont mind
we have always had the smallest one in place -- the one that will "slip" the most
Old Feb 22, 2009 | 03:42 PM
redboost10's Avatar
i have the largest one in, but now we got a dog box so it dosnt matter
i didnt know summit carried the valve. good to know
Old Feb 22, 2009 | 03:47 PM
Mr. Badwrench
http://store.summitracing.com/egnsea...alse&N=700+115
Old Feb 22, 2009 | 03:50 PM
redboost10's Avatar
are you running a carbon twin innes?
Old Feb 22, 2009 | 03:52 PM
Innes's Avatar
nah, we have always run the Tilton Cerametallic Twin Disc
Old Feb 22, 2009 | 03:54 PM
redboost10's Avatar
hmm. maybe ill have to try the smallest oriface. i run the same clutch but have always been hesitant at running the smaller ones with a cerametallic.
not sure if it matters now
Old Feb 22, 2009 | 04:11 PM
s4yama's Avatar
sorry for the dumb question, but anyone using this on clutches other than tiltons?
Old Feb 22, 2009 | 04:18 PM
ALL IMPORT's Avatar
we use it on our bug. & we use the small one as well . but its not with a tilton clutch
Old Feb 22, 2009 | 04:20 PM
Mr. Badwrench
my clutch isnt a tilton either......exedy twin.
Old Feb 22, 2009 | 06:18 PM
HondatagirlPea's Avatar
From: Between the hills of Downtown LA and Pasadena
Did you call to make the order? When I ordered my tilton throwout bearing parts I asked if it was really going to take aslong as the website noted. What they did was call them while I was holding on the other line. basically we got it a week and a half after ordering instead of a month.
Might want to call and see what you can find out.
Old Feb 22, 2009 | 07:08 PM
tepid1's Avatar
x2
I use the smallest hole as well.
Old Feb 22, 2009 | 07:13 PM
mike93eh2's Avatar
i used one on a action clutch......and i used the largest orifice.
Old Feb 22, 2009 | 07:30 PM
BlakeJ53's Avatar
I have a exedy twin and I have one. I have the biggest oriface in it but I have not had time to test the rest.
Old Feb 23, 2009 | 09:04 AM
ExospeedAMcrx's Avatar
Ya you dont have to use a Tilton Clutch setup with the Tilton Flow Control Valve. Can be used in Twin Discs or regular Single Discs. As long as you can put fittings on your hydraulic lines, you can use it.
I usually stock several sets all the time if anyone needs it ASAP.
Old Feb 23, 2009 | 09:11 AM
redboost10's Avatar
is the exedy a carbon or ceramic?
Old Feb 23, 2009 | 09:20 AM
josh green's Avatar
DAMN, it would be hard for me to justify paying $170+ tax and shipping for a piece of aluminum the size of a quarter, I understand what it does but damn.
Old Feb 23, 2009 | 09:37 AM
yellow_weapon's Avatar
the valve i will be using came from a mate that worked with hydraulics, no idea how much they are tbh as it was free, its quite small and will fit inline easily, its adjustable without messing about changing orifices or re-bleeding, you could have it in car if you wanted i guess, it has numbered increments so you can easily note settings that work well and reset it to work without slipping the clutch if you wanted.
looks similar to this (mine is with a mate that will be making up the clutch line)
Old Feb 23, 2009 | 09:40 AM
You can think of it as spending $170 on a piece of aluminum than can save parts rather than breaking a $1500 axle or $1000+ on fixing a broken transmission, plus the waste of time and money going to the track and not being able to make any runs due to breakage.
Old Feb 23, 2009 | 10:53 AM
Mr. Badwrench
ceramic
Old Feb 23, 2009 | 12:06 PM
josh green's Avatar
Well, our car hasnt been as extreme as most peoples are. I understand its function, but the price is just for the Tilton name on it.
Old Feb 23, 2009 | 05:22 PM
mike93eh2's Avatar
you do understand that the tilton fcv is not just a restrictor valve, right?
because thats exactly what your picture looks like. you better read up on what exactly the tilton fcv does..
Old Feb 23, 2009 | 06:05 PM
redboost10's Avatar
is there another brand making one?
taylor race has/had fair prices on the valve, just to pass some info along.
Old Feb 23, 2009 | 09:45 PM
Full-Race.com's Avatar
So are you suppose to keep going down in orifice size until you feel the clutch slip after shifts? I guess my question is how do you know what orifice size to use? We just put the Tilton valve in our car with the large orifice and can't feel any difference.
Old Feb 24, 2009 | 03:14 AM
Mr. Badwrench
i dont think it is designed to "slip" noticably. just enough to get everything moving together kinda like preloading.
