idle jumps up and down fan dont work...etc.
Old Feb 22, 2009 | 01:10 PM
killakalipoph's Avatar
Default idle jumps up and down fan dont work...etc.
hey guys i got a 95 turbo'd accord...running a f22a1 wit h23 manifold...anyways i finally got this together and its idles alot...from 1k to 3k....i checked for leaks by spraying carb cleaner around the manifold but couldnt find a leak...i changed out throttle body and it did the same....(throttle body came off my running car and have no issues of the idle jumping up and down)....
second problem....my fan does not come on...fuse is good..fan works when i straight wire it...thermostat switch is new...but...after the wire tuck....i magiclly had a missing plug...its to the sensor thats rite in front of the block that has the radiator hose hooked up to it....if thats the problem...where do i tap those wires to?
MindLess311
Engine Management and Tuning
Jun 21, 2009 10:27 PM
CRX30436
Dec 17, 2007 07:39 AM
EKSedAndy
Nov 5, 2007 10:15 AM
