Possible misfire
Old Feb 22, 2009 | 10:32 AM
NAHHHHH's Avatar
Default Possible misfire
Well the problem started after i replace my p28 for my b16a with a jdm p30 for the first couple days everything was fine. Now the car stutters a bit like it dosent wanna go. The cap, rotor and button have been replaced also the spark plugs and wires to. Also when i went to replace my rotor the old rotor screw was completey gone and the rotor was just barely on and had chewed up the black plastic piece inside i dont know if that helps
Old Mar 26, 2009 | 07:14 AM
audiimportech's Avatar
Default Re: Possible misfire
replace that rotor and get a new screw. make sure that it didn't burn anything like the cap. I'm not sure if this happened before or after the replacement of your ignition components. Also make sure you have good grounds.
Brett
Oct 24, 2007 07:55 PM
xstalkrx
May 21, 2007 04:34 PM
Sima
May 11, 2003 07:26 AM
PatrickGSR94
Feb 1, 2003 12:40 PM
totaled
Jan 23, 2003 11:54 AM
