help with honda fit rims on an eg
Old Feb 22, 2009 | 09:40 AM
lileghatch's Avatar
Post help with honda fit rims on an eg
Hey I have a 94 eg hatch and I just bought some 16 inch honda fit stock rims and I was wondering if anyone know how to keep it from rubbing my control arms..because I put coil overs and almost back to stock height and they are rubbing my upper control arms..wtf...help plz
Old Feb 22, 2009 | 09:42 AM
Paul-R's Avatar
Default Re: help with honda fit rims on an eg
put spacers on go to your local rim shop and ask for spacers there like 10 - 20 bucks .
this is what they look like
http://www.ezaccessory.com/PhotoGall...roductCode=601
Your welcome
Old Feb 22, 2009 | 09:43 AM
Kyle is raaddd's Avatar
Ra-ta-ta-tat dat GDD
sorry i don't know how to help.
but can you post picture of the GD3 rims on your EG?
Old Feb 22, 2009 | 09:48 AM
nsxtasy's Avatar
H-T Order of Merit
It's not that simple.
You have to make sure that after installing the spacers, you still have 6-7 full turns on the lug nuts. Otherwise, you need to install extended studs and get open-ended lug nuts.
You also lose the hubcentricity when you do that, unless you get the kind of spacers that replace the lip to center the wheels (which are not what you have pictured). Without that, you are entirely relying on the lug nuts to center the wheel, in which case there is a good chance you will have problems with vibrations. Not a certainty - some people luck out - but many people have ongoing vibration problems when they lose the hubcentricity, even when they do everything right when tightening the lug nuts.
Pushing the wheels out with spacers may also cause rubbing on the outside of the tire/wheel, and you may need to roll your fender lip to clear.
Old Feb 22, 2009 | 09:51 AM
lileghatch's Avatar
hey thanks paul r i apperciate it..and kyle i dnt have a computer i am doing this on my G1 and i took them off and put the stock stellies on but just to let u know them hoes look sick on my hatch..lol
Old Feb 22, 2009 | 09:54 AM
lileghatch's Avatar
thanks brospeh iam sure that info will help
Old Feb 22, 2009 | 09:57 AM
Paul-R's Avatar
np...
Old Feb 22, 2009 | 12:02 PM
r.wright's Avatar
yeah you prolly were rubbing the inner part of the bottom of the wheel or was the tire rubbing?
a 3mm - 5mm spacer may do the trick as stated before but make sure you have enough turns on the lugs..
well, since the subject is about 16" fit rims so im guessing these are 2009 models.
which are 16x6 +53 offset. w/ 185/55-16? or what tire size are you using?
Old Feb 23, 2009 | 06:56 AM
hmoobhero's Avatar
yeah, got a set on my bros eg. but i think they were 15s not sure but i'll check it out tonite. everything is fine and rides fine.
Old Feb 23, 2009 | 07:49 AM
lileghatch's Avatar
ya guys thanks for the help i put some spacers on it and the tire or wheel quite rubbing so tahnks to all..peace
Old Feb 23, 2009 | 01:59 PM
r.wright's Avatar
Originally Posted by solbrothers
also, the GD fit had an optional rim as well.
yessir and i believe the dealer option wheel was a 16x6.5 and glad the spacer helped.
Old Feb 23, 2009 | 08:21 PM
alright cool man,
thanks
Old Feb 23, 2009 | 08:41 PM
eazybmx's Avatar
sorry to threadjack, but 08 15" fits wont have any issues on my em1 right?
Int3graz
Jul 24, 2012 06:50 AM
bobbyeg6
Feb 11, 2010 01:55 PM
hoffmanb16
Nov 4, 2009 05:34 PM
leroyb
Feb 6, 2009 08:30 PM
