idk whats wrong with my hatch
I'm rolling down the road and it starts sputtering losing power and dies..checked oil,coolant, battery timing belt is still there. replaced the igniter nothing..gets spark. turned over slowly and and quits..btw the motors a d16y7. thanks.
Does it restart ? if not then check for spark/fuel/compression
if its all fine check ur fuel pressure (filter might be old)
if its none of the above then check ur main sensors ur car needs to run
(map,cps,etc) check if u have any codes aswell.
gas is good..had filled up 2 days before.
battery is good alternator i'm not sure of..
but i thought it would turn on if i had push started it..
eacmen
Dec 21, 2008 05:49 PM
Dee A Nine
Jan 3, 2008 10:55 AM
