z6 mini-me swap help =(
anyone get upset when you have car parts sitting around you can't put in?? yea me too. and i'm only just getting into the tuner world!
anyways, i got a mad bargin on a blown block with a z6 head. head is fine so i thought i'd look into a lil swapping. all i know that it doesn't have is the dizzy. so here's my situation:
i have a d16y6 in my ek right now. i have the z6 head, intake mani, chipped p28 and obd1-obd2a harness and i'm tryin to do a mini-me swap. other than the dizzy, what else do i need????? and where can i find a dizzy for the swap?????
also, are there any write ups on performing this swap?? i've been searching the forums and can't find anything
i live in olympia, wa, and if anyone's in the area, i wouldn't mind buying them a beer or two for a helping hand!! please help this noob!!!
Well, there may be 0DB2 to 0DB1 harnesses for your stock dizzy.
You will have to replace:
-head gasket
-Timing belt
-some oil and coolant
You may want to replace:
-Intake manifold gasket
-waterpump
-head bolts
-valve cover gasket
-dizzy o-ring
that's just off the top of my head...
-head gasket
-Timing belt
-waterpump
-head bolts
-valve cover gasket
-dizzy o-ring
check in the faqs for this for this section is all in there, that's where i've been reading up on them
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faq-d15-sohc-vtec-mini-me-massive-write-up-56k-goodbye-554053/
so i guess i don't need that much more for it then
any idea on where i can find some good gaskets?? and do i need to take the head in somewhere to get it checked??...to see if it's warped, etc.??
ok found an oem head gasket. want to be better safe than sorry so i'm looking for the intake mani gasket as well
and for the head, do i take it in and say "have your way with her"?? what do i want them to check??
Yup, it's true. The Y7 head stud in that hole would be too short to work.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/d16z6-head-onto-d16y7-d16y5-d16y8-block-d16y8-head-d15b7-d16z6-block-head-bolts-stu-1635057/
https://honda-tech.com/forums/showthread.php?t=1635057
i guess i've never heard it because most people put y8's on their y7's and z6's on their b7's.
yea i've heard this before. but i have no idea where to find a z6 stud ??
i think i'll just order some ARPs to be safe unless i find a z6 one first.....
??i think i'll just order some ARPs to be safe unless i find a z6 one first.....
haha so anyone want a wrench thrown into this situation?? i'm deploying in june and i decided what's the point of doing the mini-me if when i come back, i'll just swap the y7 for a gsr/b series
anyone interested in min-me parts?? i got a lot of other parts too! just hit up the thread link below. thanks again for everything guys!
http://www.hondamarketplace.com/show....php?t=2519630
efjones9
16
Oct 2, 2010 05:09 PM
