my h2b setup. just finished it
Old Feb 22, 2009 | 02:01 AM
nikko_SOHC's Avatar
Default my h2b setup. just finished it
check out my setup let me know what u guys think. CHECK OUT THE PICS!
Old Feb 22, 2009 | 02:14 AM
DA9racer's Avatar
Default Re: my h2b setup. just finished it
sick pics bro... what engine you go with
Old Feb 22, 2009 | 09:06 AM
turboedsupe's Avatar
What header is that?
Old Feb 22, 2009 | 09:36 AM
DSRxCandyh2bEG's Avatar
Lookin good!
Old Feb 22, 2009 | 09:59 AM
JDM JEFFREY's Avatar
very clean
nice ssr header
Old Feb 22, 2009 | 10:32 AM
nikko_SOHC's Avatar
its a jdm h22.
Old Feb 22, 2009 | 10:33 AM
nikko_SOHC's Avatar
its the ssr header.
Old Feb 22, 2009 | 10:38 AM
nikko_SOHC's Avatar
ill just make a parts list for ya'll.
jdm h22
99' si tranny(s4c)
evolution h2b kit
clutchmasters stage 3 clutch
ssr header
whale ***** intake
skunk2 mani
68mm skunk2 tb
rc 440cc injectors
walhbro 255 fp
full 3inch exhaust to stock muffler
dynoed car on 87 with full exhaust it make 200whp and 156wtq. CTR DYNOSPORTS.COM TUNED
Old Feb 22, 2009 | 10:59 AM
NmaynarD's Avatar
87????
Old Feb 22, 2009 | 11:01 AM
drellimh22's Avatar
sweet setup kid..im tryin 2 do tha same.. i got a red coupe.... with an 01 h22a
PROPS ..NICE CLEAN WORK.
Old Feb 22, 2009 | 11:02 AM
nikko_SOHC's Avatar
Originally Posted by NmaynarD
87????
87 octane fuel(its my daily driver)
Old Feb 22, 2009 | 11:13 AM
Pinho's Avatar
nice set up
Old Feb 22, 2009 | 11:25 AM
i know its ur daily but you should be running at least 91. Bone stock preludes require premium gas or they will knock, and you have a jdm motor with higher comp... i would at least use 91... imo
Old Feb 22, 2009 | 11:45 AM
nikko_SOHC's Avatar
to be honest ive run it on 91 and 87 and for the daily grind i cannot tell a difference. but when im going to the track or a sat. night or somthing i always us 91. the only reason i dynoed on 87 is because i had a full tank in the car and it was a last minute thing. a realy good tunner was in town dynoing at ctrdynosports for the day and i got a chance right then and i didnt want to try and drain my tank or anything. lol.
the jdm motors are anywere between 10.6:1 and 11.0:1 comp and usdm hondas have comparable comp to that running on minimum grade gasoline.
Old Feb 22, 2009 | 11:55 AM
solsurvivor's Avatar
Compression ratio: 10.0:1 (North America); 10.6–11.0:1 (Japan)
that's quite a difference........you definately need 91 or higher...
Old Feb 22, 2009 | 11:58 AM
98vtec's Avatar
moderator emeritus
if it was tuned for 87 then its fine.
Old Feb 22, 2009 | 12:02 PM
nikko_SOHC's Avatar
well it has never ever pinged or givin me a problem yet. if and when i re-tune it i will for sure be using 91 octane. i have plans for head work then i will re-tune for sure
Old Feb 22, 2009 | 12:09 PM
98vtec's Avatar
moderator emeritus
just to clarify, you cant always hear detonation.
Old Feb 22, 2009 | 12:21 PM
Mag00n's Avatar
nor will 'feel' a difference between 87 and 91/93 Its not for performance its for saftey.
It costs $20 to fill my gilrs 98 ex(87) and $23 for me to fill up my si(93). $3 bucks more per fill man...small price to pay to protect that $2k motor.
Old Feb 22, 2009 | 12:43 PM
dohcem1's Avatar
Nice clean done swap. Im just mad how mine isn't turning out like this. I think I'm one of those VERY few that couldn't do a successful swap =/
Old Feb 22, 2009 | 01:41 PM
superls92's Avatar
what throttle cable did you use?
Old Feb 22, 2009 | 02:08 PM
nikko_SOHC's Avatar
i used the stock throttle cable that came on the car. i did customize the bracket a little bit though.
Old Feb 22, 2009 | 02:11 PM
nikko_SOHC's Avatar
well im not a noob to cars ive been doin this for a while now this is what i do for a living every day and i thank u guys for the feed back and putting me in my place about the fuel. when u put it that way i feel stupid...lol. so ill take ur guys' advice and start putin 91 normaly.
Old Feb 22, 2009 | 02:12 PM
nikko_SOHC's Avatar
there will be more to come. ive been talking to innovative mounts about an a/c bracket for an h-series that uses a d-series compressor. so im going to try and put woking nice cold a/c on this car.
Old Feb 22, 2009 | 04:28 PM
Mag00n's Avatar
Wasnt trying to insult ya mang the setup is sick and clean
