780cc p&h with E85. how much Power.
Old Feb 22, 2009 | 12:10 AM
Civic89stdB16's Avatar
Default 780cc p&h with E85. how much Power.
i have 780cc prescions p&h injectors how much power can they support on e85. thanks
Old Feb 22, 2009 | 05:08 AM
96 GSR-T's Avatar
Default Re: 780cc p&h with E85. how much Power.
I would think you couldnt get 400whp out of 780's, depends on the dyno
Old Feb 22, 2009 | 06:45 AM
91civicDXdude's Avatar
If you are close to your power goal and maxed on duty cycle, raise fuel pressure. Going from 45psi stock to 60psi will net you around 920cc flow rate. It would be best to check with manufacturer first though to determine the maximum safe fuel pressure. Some injectors actually develop a better spray pattern at higher than default pressure.
Old Feb 22, 2009 | 06:51 AM
Karl Buchka's Avatar
780cc injectors at 85% dc on a 4 pot with E85 are good for 340bhp at a bsfc of 0.7.
Old Feb 22, 2009 | 12:19 PM
thanks for the imput i was just looking to get around 315whp out of them. thanks
Old Feb 22, 2009 | 12:26 PM
SovXietday's Avatar
I'd be REALLY careful with doing that, especially because most of us are using 1:1 rising rate FPRs and a normal intake Walbro 255 is not all that stable above 60psi if I remember correctly.
sanman000719
Feb 1, 2012 12:30 PM
85
Jan 31, 2010 02:46 PM
koczeka
Oct 30, 2008 08:52 AM
94typeR
Jun 22, 2007 07:44 PM
pg_vtec
Sep 28, 2006 03:39 PM
