90 dx hatch
Old Feb 21, 2009 | 04:19 PM
NedeN's Avatar
Icon2 90 dx hatch
Specs: 90 dx hatch, d15b2 everything pretty much stock
Hey guys, been working on a DX for awhile. Had it towed and now i got it back. Now on to the problem. It shuts off immediately after it turns on. Ive had two people i know check it out. One says it could be a fuel problem, such as an injector or my pump (which is new) and the other says it could be a "run circuit". Now ive done everything that is in my knowledge and ive searched for run circuit and have come up with nothing. So if you have any ideas please feel free to add.
Just for some background knowledge ive changed:
Fuel Pump, secondary fuel injector, new spark plugs, fuel filter and some other misc. items like seats but thats a diff story.
Old Feb 21, 2009 | 05:01 PM
ryanevansoh's Avatar
Default Re: 90 dx hatch
try replacing your main relay. its a common problem among ef's for them to go out
Old Feb 21, 2009 | 07:03 PM
Targa250R's Avatar
be professional
Does the engine continue running if you hold the key in between positions II and III?
If so, the ignition switch contact assembly is bad.
Old Feb 21, 2009 | 07:14 PM
NedeN's Avatar
naw the engine wont run longer than 2seconds and thats if i can even get it to start usually it will just sputter about in its own filth =(
Old Feb 21, 2009 | 07:16 PM
Targa250R's Avatar
be professional
Probably the main relay for the fuel injection system.
Fuel pumps almost never go bad on Hondas. I've seen 2 bad fuel pumps in the past 3 years, and our shop works on over 70 Hondas and Acuras per week. Most people misdiagnose a bad main relay as a bad fuel pump because they never bother to check for power at the connector.
Old Feb 21, 2009 | 07:25 PM
NedeN's Avatar
Alright, main relay it is thanks a lot
Oh i probably souldve mentioned it sat for about a year before i bought it. Probably shouldve said that sooner...
eg-perk
Mar 17, 2016 11:22 AM
vtecpoweredsol
May 20, 2010 08:54 AM
SofaKing
Aug 23, 2005 05:57 PM
ekoms31
May 27, 2005 08:42 PM
skud_dusty
Jan 27, 2003 09:58 AM
