vtec question
Old Aug 10, 2002 | 01:32 AM
_Endless_'s Avatar
Default vtec question
how would you know if your VTEC is not working? does it always throw a code? what are the most obvious symptoms to look for? i can still tell before if my vtec is engaging or not with a stock exhaust and muffler but now with a 2.5" pipe and a muffler i'm can't really tell anymore.
Old Aug 10, 2002 | 01:42 AM
Kamin's Avatar
Default Re: vtec question (_Endless_)
is it a SOHC motor?
youll never hear or feel vtec on a SOHC motor.
sorry.
Old Aug 10, 2002 | 10:24 AM
Malgerus's Avatar
Default Re: vtec question (KAMiN)
is it a SOHC motor?
sorry.
try my car.
Old Aug 11, 2002 | 12:33 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: vtec question (89_Y_49)
why, your slower. That mean something?
I'll feel SOHC VTEC on a slower car?
Old Aug 11, 2002 | 12:50 AM
tinkerbell's Avatar
OK,
1. goto a quiet street and do a first gear run to redline.
2. stop car, get out, open hood, unplug VTEC solenoid;
3. get back in car, do a first gear run to redline;
4. notice any difference?
HTH,
t..
PS this can be done in any gear, maybe it will be easyer to hear in 2nd?
Old Aug 11, 2002 | 01:19 AM
Nobody's Avatar
is it a SOHC motor?
sorry.
Ouch!
Old Aug 11, 2002 | 01:56 AM
Kamin's Avatar
Default Re: vtec question (Nobody)
i should have phrased that better
unless you do a cam upgrade
odds are youll never hear vtec.
if you do its not as audible as a b series.
Old Aug 11, 2002 | 07:49 AM
mugenracer's Avatar
if you have your oem airbox still attached then remove the panel filter and leave the lid off, then drive your car, you will hear the vtec clearly when it comes in. I done this on my beater civic esi (d16z6) and its very noticeable
Old Aug 11, 2002 | 08:04 AM
Pengo's Avatar
Default Re: vtec question (mugenracer)
stock with just I/E.....I/H/E......I/H/E and Zex cam..... all these combinations and i have always been able to hear and feel vtec on my sohc. granted it is much quieter and subtle then maybe a dohc, but if you really know and feel your car, you'll be able to tell. it was definitely much more obvious and audible with the cam tho. the only time i can't tell is now, since i have the greddy kit on
Old Aug 12, 2002 | 02:26 AM
_Endless_'s Avatar
Default Re: vtec question (Pengo)
the motor is b16..
Tinkerbell,
is it safe to run the motor to redline without the vtec solenoid connected?
Old Aug 12, 2002 | 05:39 AM
neumonik's Avatar
why not just hook a volt meter up to the solenoid and drive the car... see if the voltage changes?
Old Aug 12, 2002 | 07:48 AM
Ideal's Avatar
Default Re: vtec question (neumonik)
my i can feel vtec kick in on my sohc.
Old Aug 12, 2002 | 08:21 AM
neumonik's Avatar
Default Re: vtec question (Ideal)
I still say volt meter... best way to know for sure.
I can feel mine kick in too, but if you want to be 100% positive the best way to know is mesure the current.
sohcvtec97
Oct 3, 2005 12:37 AM
FaceTuned
Aug 8, 2005 10:35 AM
matraca112
Sep 7, 2004 10:36 PM
JBOCRXsiR
12
Jun 18, 2004 07:28 PM
EGinNY
16
Aug 12, 2003 12:44 PM
