whats wrong with my iacv
Old Feb 21, 2009 | 01:18 PM
EJ8CIVIC's Avatar
Default whats wrong with my iacv
ok i got my crx up and running..
91 hf with 99 d16y8 and p28
im throwing code 14 so i clean the iacv and disconnectd the battery and ecu then waited and hooked back up and still have the code
what could be the problem
Old Feb 21, 2009 | 04:10 PM
88SeeOurEx's Avatar
Default Re: whats wrong with my iacv
do you have a roaming idle?? or is your idle normal?
Old Feb 21, 2009 | 04:27 PM
DTA-Zombie's Avatar
did you hard wire teh iacv or use a harness with the plug? if you wired it check where you wired it and your pinout
Old Feb 21, 2009 | 04:29 PM
daveb91's Avatar
Pull the hazard fuse not unhook the battery.....
Old Feb 21, 2009 | 04:58 PM
Stiff_Crx's Avatar
I'm having the same problem except I have an b18a1 and the iacv hasn't worked before or after the swap
Old Feb 21, 2009 | 05:20 PM
91DBSexyTime's Avatar
thats probably because you need a new one.
Old Feb 21, 2009 | 05:24 PM
Stiff_Crx's Avatar
I've replaced it with another one not a new one but I cleaned it out with carb cleaner and the problem still occurs
Old Feb 21, 2009 | 07:02 PM
Stiff_Crx's Avatar
Old Feb 22, 2009 | 09:17 AM
EJ8CIVIC's Avatar
what dose pulling the hazard fuse deal with the check engine light?
kyang03
Aug 7, 2012 12:16 AM
halocore
Dec 5, 2008 02:39 AM
mattblack
Oct 9, 2008 12:41 PM
CimorelliCRX
Sep 19, 2003 12:21 PM
