PIC REQUEST: Denji Gen 1's with HID's
These headlights with any PnP or OEM HID lights... Not lookin for retrofit's, i wanna see the output of the stock denji projector lense.. I keep hearing it's crap, but than those same people haven't seen or have no proof that it is indeed crap... Mine have a nice cutoff, so with an HID kit, I don't see the outcome being that horrible, thanks...
I dont think so, cuz mine came as is with a cutoff projector lense and some pretty decent bulbs... i didnt think integras projectors produced a cutoff line, but mine do so i dont think they're the same... and mine were 100% brand new, never modified... im thinkin a PnP kit might not be to bad....
it would probably look good..when i had my denji's i thought about doing a PNP kit as well but i opted to clean the car up and put my stock headlights back on..the thing is i believe you would need to use an H4 kit to make it work
so i should look into converting the assembly H4 than go with a pnp kit..?? sounds like were onto something... i heard someone say they used a 9006 bulb ina H3 socket with lil modifcation, so i bet theres a way to do this... im by far not into any ghettofab **** but if there was a clean way to do this id be down..
maybe one of our HT wiring genius's could fill us in
I was thinking of using some TSX projectors to replace the stock Denji projectors. The beam cut off for the denji's are "ok" but compared to the TSX is night and day. I've ordered a set and will try this out and see what the outcome will be.
the best thing for you to do would be to get a PNP H4 kit and then mod the housing of the projector to make it fit..its cheap plastic shouldn't be hard to do..and theres nothing duct tape won't hold in place
im about 90% leanin towards tryin this... i figure if i chop up to much than ill be forced to get tsx or e55 projectors... just was tryna stay away from spendin $300+ on headlights lol...
i have no pics but the one's in my bro's hatch glares like crazy!
not even as good as my old tegs with usdm front and jdm front w/ non-hid lights....
yeah im just peepin now some budget projectors cuz the cheapest tsx ones i found were like $150 just for the projectors...
I had a Denso hid kit in my oem integra projectors and it looked fine, i just had to aim my lights up a little and it was perfect. I think if u get them and aim your lights you will be able to get the output where you want it.
$90 off ebay i got mine.. they were labeled "civic type r projectors" and when they came, sure enough Denjis is what i got... also on the box it shows a 92-95 ex/si civic with the jdm bumper moldings on the front bumper, now if i could only find them lol...
I have an extra set of denji projectors just laying around. That way you wouldn't have to hack up yours. PM me if interested.
Because #Denjis are worth resurrecting a thread.
We now have 2015 Denji's that we modify to use the bran new 2015 Morimoto XBH3c bulbs. They are uniquely designed with an offset ground wire giving the highest output and cleanest cutoff of any Denji's to date.
Example above is with a 5500K Morimoto XBH3c bulb with XB5Five 50W Ballast.
hi
did you used harness morimoto hd relay h1/h3 or canbus h1/h3?
Needs to be About 20% Cooler
I just got this HID kit with Denji's and i cant figure out the wiring. i see wire cut and heat-shrunk in the pictures above, does that mean i need to modify the harnesses i got? i got no instructions. so i don't want to just start cutting wires.
