Lighting HID/Xenon kits, Retrofits and Associated Topics
City lights for 98-01 Integra headlight?
Old Feb 21, 2009 | 09:14 AM
RockinaRHard's Avatar
Icon6 City lights for 98-01 Integra headlight?
Is there a way to get city lights working in a 98-01 integra headlights with out doing anything permant or causing water leaks?
If so what is needed and has anyone done it? Pictures would be great!
Thank you.
Old Feb 21, 2009 | 03:47 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: City lights for 98-01 Integra headlight?
You will have to take the headlights apart to get a city light into the high beam reflector. It's not like a Civic headlight where you can just drill a hole in the housing. The high beam reflector is encased inside the headlight housing, so you'll have to take the housing apart to access the reflector.
Old Feb 21, 2009 | 06:49 PM
KillBot's Avatar
Could you use one of these:
http://www.racerwheel.com/se-2800.html
http://www.racerwheel.com/se-320s.html
...I am sure they are horrible...
Old Feb 22, 2009 | 06:01 PM
So you're saying it would be a PIA?
and might wind up with water/moisture in them?
Old Feb 23, 2009 | 08:09 PM
nineohtoo's Avatar
^yeah just get a jdm front and an oem option for a city light
Old Feb 23, 2009 | 10:50 PM
I really don't care for the honda accord's front end lol
Old Feb 24, 2009 | 10:49 AM
TunerN00b's Avatar
It is that simple.
Bake headlamps, disassemble.
Remove high beam reflector from housing.
Take reflector, tape over desired location for city light. You want to place it directly below in the bulb in the reflector, so it only reduces light that shines straight up. Drill hole through tape and reflector.
Stuff 194 bulb and socket through hole.
Wire new city light in parallel with marker lamps.
The stock headlamps on an Integra aren't sealed stock. There is a vent tube at the back, to allow moisture to escape. You won't have to worry about moisture as long as you seal back up what was sealed to begin with and leave the vent in place. The heat from the low beam will dry up any moisture in there when you use them.
Old Feb 24, 2009 | 05:38 PM
Thanks!!
Honestly, I could never take them apart and put them back in working condition
I guess I'll just leave them alone...
Old Feb 26, 2009 | 10:18 AM
nineohtoo's Avatar
The accord comment was great. My accord front > bug eyes lol.
I'm sure you can find someone who can do it for a fee. or go to a junkyard or craigslist and find a pair to practice on. Good luck on getting it setup.
Old Feb 26, 2009 | 07:19 PM
Community Builder
Originally Posted by TunerN00b
It is that simple.
That'll get them in there, alright, but would leave no provision for replacing the bulb unless you take the headlights apart again.
I really don't think stock USDM Integra headlights are good candidates for city lights.
Old Feb 27, 2009 | 12:08 PM
TunerN00b's Avatar
Most people who would do such a mod, aren't thinking past tomorrow, much less 2 years from now when the bulbs will burn out.
But you're right. Use a 194 LED instead, and it will outlast the car, probably.
Me either, actually. But, they're similar to the quad headlight Mercedes cars, and those light the highbeams with a city light, so I can see why some people might want that look.
Eh, city lights are just white front marker lamps for use without headlights to allow people and cars to see you. The OEM Integra front marker lamps in the bumper perform this job just fine, and we don't mandate running without headlights like some foreign cities do (which is the only reason for city lights anyway).
Old Feb 14, 2012 | 06:22 PM
diablo2184's Avatar
Hey Patrick, would the socket from a 97+ Prelude city light be long enough to reach into the reflector from the back of the integra housing?
I am thinking that it may extend out far enough compared to the sidemarker sockets. Any other ideas how to get the bulb into the high beam reflector?
{Sigur-Ros}
Jun 8, 2008 08:19 PM
rasinhell
Feb 17, 2005 04:35 AM
N1NjA TuRtLE
Nov 9, 2003 02:24 PM
integra15
Jun 14, 2002 06:30 PM
.paul
Mar 23, 2002 09:42 PM
