flywheel bolts
Old Feb 21, 2009 | 07:35 AM
dadrought6's Avatar
Default flywheel bolts
anyone know how many foot pounds i need to torque the stockflywheel bolts on a stock flywheel in an LS tranny??
Old Feb 21, 2009 | 09:24 PM
sauceja's Avatar
Default Re: flywheel bolts
Flywheel bolts to the crank and not the tranny but its around 58 ft/lbs or more.
i use an impact haha with red locktite cuz I had a bad issue with flywheel bolts.
The clutch bolts are around 18 ft/lbs or so also.
Old Feb 22, 2009 | 04:38 AM
Since 1983's Avatar
are the D series clutch bolts the same as the B series? kind of a silly question but it's something I am going to run into in the near future.
Old Feb 22, 2009 | 09:57 AM
Andr3w's Avatar
76ft-lb to be exact for a b18. unless your auto then its 54ft-lb
Old Feb 22, 2009 | 11:00 AM
sauceja's Avatar
Yeah that sounds about right. My nitro cat setting 1 is 84 ft/lbs.
jrsh0526
Jan 24, 2014 06:27 PM
anzh86
Jul 27, 2010 09:04 PM
Will_H
May 31, 2009 10:11 PM
vaypourus
Nov 9, 2006 06:26 PM
lsvtec101
Jun 7, 2004 09:52 AM
