Rear Disc Brakes on a 91 hatch back help.....
Old Feb 21, 2009 | 04:27 AM
kyle2436's Avatar
Icon2 Rear Disc Brakes on a 91 hatch back help.....
Ok i am puttin a set of rear disc brakes off a DA integra what Brake Booster do i need to use and what Ebrake Cables do i need to use???
Old Feb 21, 2009 | 08:28 AM
JDrummel's Avatar
Default Re: Rear Disc Brakes on a 91 hatch back help.....
Can probably use the Brake Booster you have now.. Not sure about the cable but probably have to use the one from the Disc setup? I would like to know for sure aswell... Thanks for asking this
Old Feb 21, 2009 | 08:42 AM
hondacivic90zc's Avatar
Use your stock brake booster and you will need e-brake cables off of a 2 door 90-93 integra.
Old Feb 21, 2009 | 08:48 AM
Targa250R's Avatar
be professional
You don't need to touch the master cylinder or booster at all; you just reuse your stock parts. Upsizing the master cylinder is only required when using front calipers with larger pistons. 7CLP13S rear calipers require the same amount of fluid to move as the stock wheel cylinders.
You will need the e-brake cables from the DA. 3-door is preferable; 4-door cables will work but are a bit long.
Old Feb 21, 2009 | 08:53 AM
JDrummel's Avatar
Cool... Thanks
Old Feb 23, 2009 | 07:42 AM
xileap2's Avatar
I have a set of DA ebrake cables, I didn't like how it fit on my ef8, so I have no use for the, let me know..
Old Feb 23, 2009 | 11:56 AM
CRXminiZ's Avatar
i did this to mine, the da cables are fine, maybe a little long but you can find a place to tuck them over the gas tank. did the master cylinder swap with the fasbrakes fronts.... it gives a lot more power... easy to lock up the fronts even 235/45/17s. I also swapped the proportioning valve to a 40/40 which I think hurt the situation. id try the 30/40 first, as thats what im swapping back to this summer to check if the brake ballance is any better.
Old Feb 23, 2009 | 03:42 PM
Slystone's Avatar
youy can do like me......just swap a 91 prélude 15/16 big reservoir master bolt on in your OEM EF booster! ;o)
Old Feb 23, 2009 | 05:52 PM
Targa250R's Avatar
be professional
There's no point in doing that with stock front calipers.
Old Feb 23, 2009 | 05:56 PM
LowFlyin''s Avatar
...or you could just swap the 1" master cylinder and larger booster from a 94+ Integra GSR. ...but you probably don't need to.
hammergunner
Mar 11, 2009 06:04 PM
jrockets
Jan 17, 2007 02:03 PM
dxcivic
Oct 15, 2006 02:23 PM
jarvis199
Apr 29, 2005 12:57 PM
D-Man
15
Nov 9, 2001 06:27 PM
