y is my civic getting terrible gas gas mileage
Old Feb 20, 2009 | 06:57 PM
boostedefhatch's Avatar
Default y is my civic getting terrible gas gas mileage
i have a 91 ef hatch with dpfi and i am getting very shitty gas milage like twenty miles a gallon thats terrible for a honda
Old Feb 20, 2009 | 07:23 PM
SuM Honda's Avatar
Default Re: y is my civic getting terrible gas gas mileage
Because you have a heavy foot or a bad pcv valve or a dirty filter or a gas leak or someone is stealing gas from your car or ....Vague questions lead to vague answers.
Old Feb 20, 2009 | 07:29 PM
shyguy4no1's Avatar
sadly its true... you have to be more specific... and besides have you done a tune up lately? Or how about the whole switching between only one injector to two... I suffer from that problem... and while I am thinking about that... When I rev it to a specific rpm (I don't have a tach) it sputters when the second injector turns on. I cleaned out the iacv and I am unsure where to go next so I am thinking maybe fuel filter maybe?
Old Feb 20, 2009 | 07:30 PM
by filter u mean air filter? mine i brand new, or fuel filter? should i just buy a new fuel filter and pvc valve btw how much does a pvc vale cost?
Old Feb 20, 2009 | 07:33 PM
shyguy4no1's Avatar
if your air filter is new check your plugs and wires, oil, air pressure in your tires ect.
what is the iacv? i think i found something on that but cant remeber
Old Feb 20, 2009 | 07:34 PM
wires and plugs seem to be good
Old Feb 20, 2009 | 07:38 PM
shyguy4no1's Avatar
on the right side of the of the the dpfi connected by 1 electrical switch and 2 hoses. Just use carb cleaner.
Old Feb 20, 2009 | 07:40 PM
ok i will try that tommorrow when i get off work thanks
Old Feb 20, 2009 | 07:43 PM
shyguy4no1's Avatar
no prob
Old Feb 21, 2009 | 01:35 AM
traxxasx's Avatar
check tire pressure
change oil
change air filter
change fuel filter
change oil filter
change pvc valve
clean intake and injectors (2)
redo timing belt (make sure its all TDC)
check ignition timing (make sure its 16*)
new cap and rotor
new plugs (gapped to correct size)
New plug wires (make sure in right firing order)
new o2 sensor(s).
Run sea foam
i bet after than you will get 30+mpg.
04AccordEX
Jan 23, 2008 06:19 AM
Blamm!!
Feb 5, 2007 07:59 AM
high23lhatch
Nov 20, 2006 04:29 PM
duppykiller1
Mar 21, 2003 04:36 PM
LS Teg
Feb 21, 2003 10:08 PM
