y is my civic getting terrible gas gas mileage
i have a 91 ef hatch with dpfi and i am getting very shitty gas milage like twenty miles a gallon thats terrible for a honda
Re: y is my civic getting terrible gas gas mileage
Because you have a heavy foot or a bad pcv valve or a dirty filter or a gas leak or someone is stealing gas from your car or ....Vague questions lead to vague answers.
sadly its true... you have to be more specific... and besides have you done a tune up lately? Or how about the whole switching between only one injector to two... I suffer from that problem... and while I am thinking about that... When I rev it to a specific rpm (I don't have a tach) it sputters when the second injector turns on. I cleaned out the iacv and I am unsure where to go next so I am thinking maybe fuel filter maybe?
Originally Posted by SuM Honda
(Post 37494244)
if your air filter is new check your plugs and wires, oil, air pressure in your tires ect.
Originally Posted by shyguy4no1
(Post 37494311)
(Post 37494342)
on the right side of the of the the dpfi connected by 1 electrical switch and 2 hoses. Just use carb cleaner.
(Post 37494398)
no prob
check tire pressure
change oil change air filter change fuel filter change oil filter change pvc valve clean intake and injectors (2) redo timing belt (make sure its all TDC) check ignition timing (make sure its 16*) new cap and rotor new plugs (gapped to correct size) New plug wires (make sure in right firing order) new o2 sensor(s). Run sea foam i bet after than you will get 30+mpg. |
