walbro 255lphhp install question
Old Feb 20, 2009 | 04:19 PM
nextproject97's Avatar
Default walbro 255lphhp install question
I have a gsr swapped hatch that needs a new fuel pump I already have the walbro 255 for my soon to be installed supercharger .However my current pump in the tank is going bad (had to hit the bottom of tank today )can I install the walbro 255 with just the stock frp I have read the endyn regulator mod but then I have talked to and read that the stock regulator will be just fine with the 255 !!
Old Feb 20, 2009 | 05:31 PM
KuEy's Avatar
Default Re: walbro 255lphhp install question
yes, you can install the 255. i've done that before and it's okay. it's not like it's bigger injectors that'll flood the motor.
Old Feb 20, 2009 | 05:43 PM
thanks
Old Feb 20, 2009 | 06:05 PM
KuEy's Avatar
no problem.
Old Feb 21, 2009 | 12:50 PM
installed walbro255 im my gsr swapped ek hatch today was very easy to do.I was just very careful removing and installing pump from the tank and had no trouble car runs like it should no fuel system modification all stock except the pump
spoon95eg
Jan 11, 2006 03:06 PM
luti
Oct 29, 2003 01:48 AM
rustycivic
Mar 25, 2003 06:32 PM
rob1208lv
Feb 11, 2002 06:08 PM
