Stalling Question. Please HELP
So when im driving my car and push in the clutch when the car is running at any bit over normal idle RPMs the cars RPMs drop and the car cuts off. Even if i rev it at a dead stop and the rpms come back down and the car shuts off. The car runs perfect otherwise. I have no idea what this could be. I cleaned the IACV and all. What else can i do? PLEASE HELP
it has always been acting this way since i got the car. I installed the new transmission and clutch and flywheel and it still does it. I have no idea
main relay would be my guess. are you throwing any codes? on the main relay if the wires get loose or are corroded and make a bad connection the car will die like so. i just got done fixing mine from doing this earlier today!!
Well i guess it only really happens after warmup. And its only when i rev up the engine and RPMs drop back down and they drop back down to like 300 rpms and the car dies.
First check the ignition coil per the manual at autozone.com and http://www.tegger.com/hondafaq/start...s.html#badcoil
